Egr system, What a pain in the rear!
I just can't seem to get this right. i been troubleshooting the egr system on my car(1994geo prizm with 1.6) When i bought this car it had a engine check light on. the prior owner took it to the dealership and they said it was the egr temperature sensor. by the way the egr temperature sensor are on the car that were california emission vehicles from 1993-94 if i'm correct. so as soon as i bought it i took it to smog. got labeled a gross poluter which i found funny. i went home with my new but used car and i tested the temp sensor myself and at 100 c the reading was 14 ohms which is within spec. so i went back to the smog shop with my check light reseted. this time i ran and passed the 25mph test. but failed the 15mph. at this point i thought that the egr valve was the problem so i replaced it with another I bought a used one which i cleaned out and vacum tested to make sure the vacumm would open and close. but i still am getting the check light. As a last resort i have replace the egr vaccum switching valve because it read 44ohm which was within spec but i felt it was too close that it could be a problem. I also had a chat with a toyota part department worker and he said that a lot of the repair shops replace this part before all else, if this part doesn't do the trick they normally just replace the egr and call it a day. but sadly i am still getting the check light. i know that its not the ecm. my gas mileage is pretty poor. about 250 a tank with a manual. i know the egr is the problem. anyhow does anyone have any experience or suggestions in what i should do? the only thing left would be the vaccum modulater. but i highly doubt thats the problem. Any advice would be most greatful.
