HUGE backfire out the intake manifold???? Flames!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2005, 09:10 PM   #1 (permalink)
View Corollenertia's Photo Gallery
Okay im nearing the end of my swap so to speak and i tried to start it and every thing seems tip top. But when i try to start it I get this huge back fire out the intake manifold t that shoots a blue and yellow flame out the throttle body and blows the intake pipe off. its a sr5 to 4age swap.I cant figure it out really my guesses are the motor is rotating the wrong way and going thru the combustion cycle in reverse just a wild guess or my timing is off on the blet ( if it is is the 4age a interference or non interference motor?) And what suggestion are ther for getting rid of this flaming back fire and getting the motor running throw them at me like I AM STUPID.... PLEASE I just want the thing to come on ive been sitting in my garage in the car for like a whole semester imagining it coming on and shifting thru gears sitting stll i cant take it any more . ANY help GREATLY APPRECIATED----- thanks Corollenertia
Corollenertia is offline   Reply With Quote
Old 07-05-2005, 09:19 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
yor cam timing is off or u got the firing order wrong
Old 07-05-2005, 09:51 PM   #3 (permalink)
Firing order is right un less i have the distributorcap is on back was hey the black plug thing that on it to let water out of the distributor is that supposed to be on the the top or bottom of the capwhen mounted if anyone cap post pics of it installed properly please post them so i can see visually. umm where are the timing diagram and timing faqs on the timing job. so i can check. IS the 4age a interferecne motor or non-interference motor? thanks for the help
Old 07-05-2005, 10:38 PM   #4 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Non-interferance.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 07-05-2005, 10:40 PM   #5 (permalink)
Peter's Avatar
View Peter's Photo Gallery
ids have to say time ing , and id get it down asap cuz a littel timeing problem isnt to bad , but when u got pistons firing when ever they want thats not the greatest
Peter is offline   Reply With Quote
Old 07-05-2005, 11:46 PM   #6 (permalink)
lol i think i know what my problem is . Lets just say when doing the swap and trying to remove thepowersteering pump i removed the distributor cap to get a better angle to take off the pump and bracket etc.... here is the dumd ass eclipse turbo owner who never had a distributor rotor style ignition system on a car he owned in his life until now took the distributor out and payed no attentiont o the motors crank position in reference to TDC or even marked the distributor sets it on a shelf has no clue if its been rotated or if any markings are on it to line up and sets it on a shelf. does his pump and braket and slaps it back on. hmmm i wonder what happened. every thing is off time on the ignition system. sound right on the money guys. i feel like a dumbass for treating my ae86 project like its my eclipse turbo. its like trying to compare a mclaren F1 to a power wheels corvette.
Old 07-06-2005, 02:56 AM   #7 (permalink)
View 94_Rolla_Guy's Photo Gallery
ok this should be easy to fix. it sounds like you got it firing during the valve overlap. heres the proceedure:
1. remove distributor and valve cover
2. rotate engine so that cylinder 1 (cylinder closest to belts) is at TDC on the compression stroke, look at the cam lobes to determine if your on TDC of the compression or exhaust/intake stroke, TDC can be found by the timing portion on the crank pulley, align the notch in the pulley to the zero mark.
3. remove distributor cap and turn the rotor manually till its pointing to where the number 1 terminal on the cap would be.
4. without turning the engine slide the distributor in ( don't turn the rotor much keep it pointing to the cylinder 1 terminals location )
5. loosely tighten the bolts
6. hook up electrical
7. time the engine normally with a timing light to factory spec
8. tighten down mounting bolts
9.DONE have fun
this should work thats how ive done it a few times, did it today infact, lol
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-06-2005, 11:35 AM   #8 (permalink)
thanks man i hope this is the last of my problems with the car and the engine install.
Old 07-06-2005, 01:37 PM   #9 (permalink)
Now school me on 4age injectors 101
alright Guys thanks for all the help back fire problem solved now that i have it timed properly i still cnat get it to start. It trys though But only when I use starter fluid. Ioriginally turned the key turned the motor heard my noisy under hood inline fuel pump and heard it pressurize the line the sound changes so i know. Then tried to start it i got no sounds of combustion at all what so ever. If there was combustion id probably see it and definitley hear it seeing as how I dont have exhuast from after the manifold back. well i checked the fuel pump to make sure its working and you could see fuel visibly being drawn thru my glass cased fuel filter( its on the low-pressure side of the pump. and i could feel the fuel line on the hihg pressure side had pressure on it. It definitley a gas charged line and its in the fuel rail as well because it goes out the fuel pressure regulator gas tank return.
Here is the dilly. I spray starter fluid in the intake and here s what i get it sound like its bumping over and after like 15 20 mins of trying to start it the exhuast manifold is hot . so I think I am moving in the right direction. But this leads me to belive my injectors are not opening and closing and spraying fuel but all of them cant be like that. SO how do I trouble shoot for this. What could I have missed that would cause this on the install.?
Ive never been so happy when my car didnt start up because I am so close to driving it.
Old 07-06-2005, 02:02 PM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
Noisy underhood fuel pump? Any idea what the pressure is?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 07-06-2005, 04:04 PM   #11 (permalink)
it has 125 max cut off is what it can provide. But i swear no fuel is is being sprayed. and 170 liters per hour. i think i stated it above some where. i talked to the guy who has 2 and he uses a saab fuel pump saab turbo fuel pump from 900s for his and ha s no problems mine is from a volkswagen or audi car.its like 10psi more than a gts fuel pump i believe but i think the fpr is handling it very well because nothing has burst. Its only noisy because its under my hood. attached to where the suspension struts are in the engine bay.
