ok... those numbers are way off.....
early bigport 4age's are 220cc @ 48psi (blue top), low ohm
later bigport 4age's are like 240cc @ 48psi (tan), low ohm
smallport 4age's are 250cc @ 48psi, high ohm
silvertop and blacktop use the same (side feed) are 270cc @ 48psi, high ohm
4agze is reddish and 365cc @ 48psi
yes, people have gotten higher numbers from those that blueprint their injectors... but those tests are generally done higher than the stock FPR keeps the fuel at
