well.... when we were moving, we had to clean the old garage out....... there were several parts to cars that we didn't own.... there was a set of (cheap) front coilovers from a CRX (one with the full strut assembly, the other just with the collar, nuts, spring, & top retainer)..... so, i was thinking that the front of the ae92 looked a little high, & i would attempt to put them on..... worst case scenario i figured would that it would look good but ride terribly & i can just swap the old springs back in...
well.... first off when i got the ae92 strut assemblies out i realized the collar wouldn't fit over part of the strut....... i easily took a dremel to it & shaved it down enough for the collar to fit snugly (i figured that could also act as something to hold the spring in place better)....
after a little work, i was able to get the collar on:
(sorry it's sideways... i'm too lazy to switch it, lol)
obviously the spring fit just fine...... though the collar & spring were shorter than the old spring (with the collar at fully lowered).... i started with the first side about 1 1/2" up (shown).... however, to get the top retainer on i had to drill out the top hole...... which was easy as the retainer was aluminum....
when i finished one side... i wasn't too pleased with the differences in sides....... in fact, at first what i had before was about 1/2 lower.... after raising the car up & bringing the coilover down to fully lowered, the 2 sides still seemed about the same...
i thought to myself, well the other springs might be holding that side up a bit still..... i'll do the other side anyways
well....
if anything it *might* be a 1/4" lower than before.... but the ride is terrible & it makes noises over bumps.... i'm gonna go back to what i had.... i'm thinking i might try getting my old springs & cutting a coil off, see how that goes though...
