GTS dash/instruments - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2005, 12:48 AM   #1 (permalink)
dirt666's Avatar
View dirt666's Photo Gallery
...anybody, does the 1988 GTS dash cluster include an oil pressure & voltmeter guages? I've got an 89 SR5 and my dash only has the tach, water temp, and fuel guages. Also, just out of curiousity, does the automatic tranny from the 4AF bolt up to the 4AGE? I never thought I'd ever have an automatic, then I broke my leg and bought an Automatic out of neccesity. Now I kind of like it. The car has cruise control, power steering, and with the automatic it's just a dream to drive.
dirt666 is offline   Reply With Quote
Old 07-13-2005, 12:57 AM   #2 (permalink)
Gameroom cash: $134355
that's a seperate gauge set...... where you have the door indicator & oil dummy light is where the gts voltmeter & oil pressure gauges go.... i've done the swap, it's pretty simple
Old 07-13-2005, 01:12 AM   #3 (permalink)
dirt666's Avatar
thanks....what other swaps have you done from GTS to SR5? I've got a chance to get an 88 GTS suspension/14" alloy wheels, etc. Not sure if it's worth it, although my front struts are shot and I could use the GTS strut-bodies, as the SR5 struts are sealed dealer only units.
Old 07-13-2005, 10:40 AM   #4 (permalink)
View White89SR5's Photo Gallery
toyotaspeed90 to swap the guages into the SR5 will I just need the guages or will I need pieces from the wiring harness and a sending unit of some sort? Thanks in advance!!
Hear no evil...Speak no eveil...If you don't bring that s**t around you...You ain't got nothing to worry about!!
http://WWW.MORECASHFLOWNOW.COM
Extra Cash Is Always Good!! Click the link to see how to get it!!
White89SR5 is offline   Reply With Quote
Old 07-13-2005, 12:45 PM   #5 (permalink)
you'll need the 4age oil pressure sending unit as well..... same thread & location on the block
i would get the wiring if possible
Old 07-13-2005, 01:09 PM   #6 (permalink)
Is the location already on the block or does it need to be drilled?
Old 07-13-2005, 02:21 PM   #7 (permalink)
Old 07-28-2005, 12:00 AM   #8 (permalink)
dirt666's Avatar
fork
