white smoke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2005, 11:01 AM   #1 (permalink)
View Irene's Photo Gallery
Canada white smoke
Hello everybody!
As I was driving my Corolla 97 on the freeway this morning, there was white smoke behind it for about 15 sec or so. Never happened before... What could it be?
THANKS!
Irene is offline   Reply With Quote
Old 07-15-2005, 12:07 PM   #2 (permalink)
View lifeisviewtiful's Photo Gallery
maye be burning oil
lifeisviewtiful is offline   Reply With Quote
Old 07-15-2005, 12:08 PM   #3 (permalink)
Canada
Wouldn't the smoke be black and not white if it were oil?
Old 07-15-2005, 12:11 PM   #4 (permalink)
irene you're right.
Old 07-15-2005, 12:32 PM   #5 (permalink)
Canada
If it is water vapor and not oil, I am curious how it gets into the exhaust system...
Old 07-15-2005, 12:32 PM   #6 (permalink)
View corolla_racer's Photo Gallery
White smoke=Coolent burning
black=oil
corolla_racer is offline   Reply With Quote
Old 07-15-2005, 12:38 PM   #7 (permalink)
Canada
black=oil
But the coolant level is fine - I am not losing any.
Old 07-15-2005, 12:39 PM   #8 (permalink)
View hachi_slow's Photo Gallery
Originally Posted by Irene
Hello everybody!
THANKS!
Could just be condensation in your exhaust pipe after sitting overnight. If you're that worried, do a compression check to see if it's your hg or anything else.
hachi_slow is offline   Reply With Quote
Old 07-15-2005, 12:43 PM   #9 (permalink)
Canada
Head gasket? Where is it in Corolla 97?
Old 07-15-2005, 01:17 PM   #10 (permalink)
View karazy's Photo Gallery
Oh oh. It 's in the same place as every engine. It's the gasket between the head and the engine block.
How much smoke are we talking about?
karazy is offline   Reply With Quote
Old 07-15-2005, 01:20 PM   #11 (permalink)
Canada
Damsel in distress thanks all of you who've contributed so far
Old 07-15-2005, 01:23 PM   #12 (permalink)
It did it once today on the freeway, when I was already at a steady speed, but only for about 15-20 sec. Scared the bejesus out of me. I'll watch it to see if it keeps happening.
Old 07-15-2005, 01:41 PM   #13 (permalink)
View Jester8759's Photo Gallery
black=oil
I thought burning oil was a blue smoke?
Jester8759 is offline   Reply With Quote
Old 07-15-2005, 03:20 PM   #14 (permalink)
It definitely sounds like a HG problem. A short burn like that, would not be noticeable in the coolant level. The fact that it started and stopped, while highway driving is a bit strange. It is possible that the leak sealed itself, temporarily. I would check the oil and coolant for signs of cross contamination. It wouldn't hurt to pull the spark plugs, to see if any of them appear to be wet or cleaner than the others. The next start, after a prolonged sit, should let you know if a leak still exists. The white smoke plume will be there at start up.
If there are no signs found, it wouldn't hurt to add a can of stop leak, just to be safe.
Old 07-15-2005, 03:50 PM   #15 (permalink)
View stubborn1's Photo Gallery
Someone already mentioned checking for signs of a bad head gasket, but I thought I would add what to look for.
Pull your oil dipstick out and look for greyish milky type deposit right above the line of the oil. Foam of any type on the dipstick is also a bad sign.
Take off your oil fill cap and look underneath the cap for the same types of deposits mentioned above.
stubborn1 is offline   Reply With Quote
