1998 Corolla - Where to buy the fuel filter that's under the hood?
Good Day,
Our car is a 1998 Corolla with just over 76,000 miles. It hesitates at random moments so the first thing to do is replace the fuel filter. Oh, that sounds so simple. I talked with a local mechanic. He said the fuel filter is in the gasoline tank. And he said the fuel filter has a screen mesh that almost never clogs, and if it did clog, the filter has a bypass.
But, under the hood there is something that looks a lot like a fuel filter spliced into the gas line. It’s a black plastic cylinder about an inch and a half long and an inch in diameter. It has a factory clamp on each end, the same clamps that are on the other small hoses, so it must be an original part.
The mechanic and a clerk at the local auto parts store both said they have no information on this filter. I checked out a Haynes manual and it does not mention this filter. Does anybody have one of these it-looks-a-lot-like-a-fuel-filter things in their Corolla? And do you know where I can buy one?
If I can’t find any info on this filter, my thought is to find a fuel filter that’s about the same size, for a 4 cylinder engine, and give it a try.
Thank you for your thoughts. Good driving to you, Anthony
