Well, first off, I am a mechanic. I have tried to get a handle on some sort of pattern. So far, this has happened twice. Both times I was running 55-60 mph and going straight. The light rumbling sound (doesn't sound anything a wheel bearing) seems to be coming from the front somewhere. Then the car pulls noticably to the left. Not to the point of really having to hang onto it, but would definitely change lanes if I were not holding the wheel. Then, just like it started, it goes away. I have driven the car all week and have had no problem. I put the car on the rack at work when I first bought it and checked all the front end components. This is when I found the bad idle and pitman arms. Everything is tight, tie rod ends linkages, everything. This is going to be a hard problem to find until it gets a lot worse than it is now. I am thinking some kind of problem with the PS, maybe a valve sticking or something like this. It never hurts to ask others with similar cars, as if it is a problem specific to Corollas, probably someone else has had it. The rotors do need to be turned, as there is a little shake when braking, but not so bad that it can't wait until the next brake pad replace. It sounds and acts almost exactly like a tire going flat.
