Knock sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 09:21 AM   #1 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Knock sensor?
I have just been thinking. I have an un-findable engine light on my 20v which is causing it to run EXTREMELY rich. It also has a tendancy to switch itself back to normal at times, but when it does it is way off timing wise.
Does this sound like a knock sensor? Or could the timing issue just be because i checked and changed the timing while the light was on to try and rectify the situation in the first place?
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-27-2005, 01:51 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
a Knock sensor would retard timing, but I think the 20V doesnt have such. I think it might be the oxygen sensor. When you changed the timing, did you plug the service connector and then adjust it, if you didnt, your timing is WAY off and since the 20V is a low emissions engine it would blink the check engine light.
Old 07-27-2005, 02:07 PM   #3 (permalink)
Gameroom cash: $134355
um, 20v does have a knock sensor...... a bad o2 sensor would cause the excessive richness.... and generally the cel doesn't go off from a bad o2 sensor until it's pretty much toast....
Old 07-27-2005, 03:21 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Severe timing error would cause the knock sensor to try to retard the timing, because it thinks the engine is knocking, which might in a bad case in some cars cause the check engine light to turn on, in the even the timing cant be adjusted by the ECU. Then again, I dont have much experience with knock sensors and them with 20V's...
Old 07-28-2005, 04:05 AM   #5 (permalink)
Country Hick
thespud's Avatar
o2 sensor is brand new. Temprature sensor is brand new. TPS is brand new. The CEL codes dont work with this engine light as the light is OFF when the ignition is on but not started and the engine light ON when running. Which is why i am starting to think that it cant be timing. The diagnosis connector was shorted when i timed her too.
