Help with 82 Corolla 1.8 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 07:45 PM   #1 (permalink)
View oldskool82's Photo Gallery
Hello ... My name is Kellie ... I own a 1982 Toyota Corolla 1.8 ... I am haveing a little bit of trouble with it ... I need to know if it has a internal or external regulator on the altanator ??? I bought it from some one who had NO IDEA what they were doing ... The altanator that is in the car says it is external, but we can not find the regulator any where ... Can someone direct me to where it might be located ??? Also, there is a white thick wire that I know is a ground wire ... Where does it connect to ??? And one last thing ... Does anyone have a schematic for the wiring, just the alternator wiring should do ??? Or anyone know where I can get one ??? Thank You so much for all the help !!
oldskool82 is offline   Reply With Quote
Old 07-28-2005, 04:13 PM   #2 (permalink)
View Hemi3TC's Photo Gallery
If you have a white wire that goes to ground then it is a US spec external regulated alternator. It also has a round connector plug. Follow those wires to the regulator.
h3tc
Hemi3TC is offline   Reply With Quote
Old 07-29-2005, 05:16 AM   #3 (permalink)
View smarriott's Photo Gallery
I am looking for an 81 corolla, are you interested in selling, or know of any others for sale. Must be a Standard.
smarriott is offline   Reply With Quote
Old 07-29-2005, 07:50 AM   #4 (permalink)
h3tc
Ok ... Thank You ... But maybe you can help with the problem I am having ... I bought the external regulator the other night, there is not one already in the car ... But the alternator that is in the car says it uses an external regulator ... You see, the person I bought this car from had no idea what they were doing ... The wires from the alternator melted ... Which I am starting to think happened because he did not have the regulator ... When I got the car 6 months ago, it did not start ... Now it starts, but isn't charging the battery ... Which is now our only problem ... I bought the Chilton's Repair guide with the wiring diagrams, and I think I might be missing some of the wiring ... I seen the round connector plug off the new regulator, is there supposed to be a round connector coming off the alternator ??? I am so lost with this car .... It is very hard to find parts for it where I am ... And right now it is all original with 93,000 miles ... Any more help you could offer will be greatly appreciated !!!
Old 07-29-2005, 07:51 AM   #5 (permalink)
As of right now, it is not for sale ... But thank you for inquiring ... If I fix it and change my mind, I will contact you !!!
Old 07-29-2005, 11:26 AM   #6 (permalink)
The alternator will have a connector on the back for a plug connector from a wiring harness that goes between the alternator and the regulator. That must have been the wiring harness that melted.
The charging regulator looks to be mounted on the firewall. somewhere around the brake master cylinder. Since you have a REG look for one similiar on the firewall.
If you check the wiring diagram for your ALT and REG. The ALT has four wires that connect to the REG, N, B, E and F . But the REG needs six wires to function. The two additional wires come from the igntion IG and the charge fuse L .
So you must try and located the melted bits of harness find the ends and look at the connectors. The 4 terminal connector goes to the ALT for E,F, N, B then all six go to the REG E,F,N,B and L, IG in a six terminal connector.
Alt 4 wire harness -> main harness -> 2 wire + 4 wire -> 6 wire harness to REG
two separate harnesses connectors one for ALT and one for REG.
So I guess you will need a new ALT to REG harness or someone to rewire your ALT and REG.
Also make sure your battery is charged up before you hook up the alt and REG. An alternator is not meant to charge a dead battery and may burn things up if tried. Which
may have happened to the previous owner.
good luck
h3tc
PS
I am just looking this up from the service manual. My 82 uses the internal reg. So I have not actually seen these pieces but am familiar with charging systems.
Old 07-30-2005, 09:33 AM   #7 (permalink)
Thanks Hemi3tc .... You help is much appreciated .... Only one problem ... Still can't find the regulator ... Could it be possible that this car uses the internal ??? The vin # starts with JT ... Does that help or mean anything ??? This is so fusterating !!!! Thanks again for all your help !!!
Old 08-01-2005, 05:15 PM   #8 (permalink)
View Limnos's Photo Gallery
My '81 Corollas (not for sale ) have external voltage regulators. They're a black box about the size of a pack of cigarettes (sorry for being politically incorrect) bolted onto the housing for the suspension at about the level of, and midway between, the brake master cylinder and the battery. Unlike many other bits and pieces it is really easy to see. I'm at work right now so I can't look at the car and tell you about the wiring. I seem to recall a small separate wire leading out of the regulator to something also screwed onto the mounting.
To the guy looking for an 81 Corolla: Look at the for sale section of www.toyota3tc.com There was somebody parting one out last week.
1981 Corolla Wagon, 5-speed, 159k miles-- my winter wheels
1981 Corolla Wagon, AT, 125k miles-- my summer wheels
** I replaced a horn. Isn't that mod. enough? **
Limnos is offline   Reply With Quote
Old 08-14-2005, 01:44 PM   #9 (permalink)
View BIMBOTRD's Photo Gallery
Che For A Suare Box In The Driver Side Shock Tower
BIMBOTRD is offline   Reply With Quote
