P0171 error code in corolla 2001 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2005, 09:06 PM   #1 (permalink)
View kulkarni_ash's Photo Gallery
Hi
I have a 2001 toyota corolla with 107,000 miles on it.
The check engine light came on, so i took it to AutoZone and the error code i got from them was P0171 (system too lean)
What are the possible causes and how to fix it.
is it some thing serious, i drive 40 miles each way to work.
do i get it fixed as soon as possible
Ashish
kulkarni_ash is offline   Reply With Quote
Old 07-28-2005, 12:09 PM   #2 (permalink)
View stubborn1's Photo Gallery
P0171 relates to a reading your oxygen sensor is picking up. The first thing you should check is the output voltage to make sure it is within specification. If the voltage is off, replace the O2 sensor in question.
stubborn1 is offline   Reply With Quote
Old 07-28-2005, 01:48 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
change your fuel filter if you havent and then clean the injectors. then worry about the sensor.
^ and leaving it that way!
Old 07-28-2005, 07:20 PM   #4 (permalink)
View OmarR's Photo Gallery
The fuel filter should be in-tank, and a hassle to get to. After 107K miles, it would be wiser and easier to change the 02 sensor first.
OmarR is offline   Reply With Quote
Old 07-28-2005, 08:14 PM   #5 (permalink)
the light is off again
Hi
it is very weird, but the light is off now, it comes on some times and then it is off again after i drive about 20 miles.
what do i do, do i still change O2 sensor, and change fuel filter
is there any think i can put in fuel to clean fuel system
Ashish
Old 07-28-2005, 08:20 PM   #6 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
ashish it'd be best to clean the maf before buying anything. your symptoms sound identical to many that have had dirty maf sensors on their 01's so clean it. dont worry about fuel additives or fuel filters, thats not going to help with this problem, but you can buy chevron techron to clean your system out if you want.
PS: check my reply on the other forum that you posted this same question on.
01loadedLE is offline   Reply With Quote
Old 07-28-2005, 11:42 PM   #7 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
had a system too lean code pulled from my 01 corolla LE
does your car have any hesitation? irratic idle?
if so it's probably a MAF sensor..
rated_w is offline   Reply With Quote
Old 07-29-2005, 12:42 PM   #8 (permalink)
115k miles
01loadedLE's Avatar
btw I had niether of those symptoms when my maf sensor was faulty, yet fixing the problem has kept the c.e.l. away now for well over a year.
Old 08-23-2005, 12:25 PM   #9 (permalink)
View realistic's Photo Gallery
did you ever find out what the problem was? i am having the same issue with my 2001 corolla. an update would be awesome!
realistic is offline   Reply With Quote
Old 08-23-2005, 03:01 PM   #10 (permalink)
Seems there are issues with MAF sensor, i did change the air filter, and then tried to clean the MAF sensor using contact cleaner, but i guess it screwed up some thing and now i am getting P0300 code also, i am trying to find out how to check the ground circuit, and find out how to test it the MAF sensor is not working,
After that going to change my MAF sensor and see what happens
I dont know what the real issue is , but my car is giving my about 36 miles per gallon on highway so dont know what to make out of it, i read some where that if the MAF sensor or O2 sensor is faulty then the milage goes down..
Let me know if you are able to fix it, i will tell you if i am able to fix it
One thing for sure, iam trying to avoid going to dealer who charge way 2 much for it
Old 08-23-2005, 04:36 PM   #11 (permalink)
115k miles
01loadedLE's Avatar
partznet.com had the best price I could find for the maf sensor, it was $128 shipped and I installed it myself.
Old 07-17-2006, 08:31 PM   #12 (permalink)
HI
I was able to fix it by changing MAF sensor, and i also change O2 sensor, some how i am getting P0420 error code,
any ideas
Ashish
Old 04-04-2007, 10:11 PM   #13 (permalink)
View XKWISIT1's Photo Gallery
Canada
The P0171 code that you are getting on your Corolla is caused by a bad mass air flow sensor, which can be found on the tube going to your air box, replacing the sensor and clearing the code will do the trick.
XKWISIT1 is offline   Reply With Quote
