clutch question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2005, 02:40 PM   #1 (permalink)
drei's Avatar
View drei's Photo Gallery
Canada clutch question
hey guyz...never had this problem so im not too sure what to make of it...when i have to chnage gears, i have to push the clutch pedal all the way to the floor and sometimes when i gotta reverse i have to try 2-3 times before i can put it in gear...does this mean my clutch is dying on me? please help...
Time does not exist in the future. Time was only invented by man so that he can tell the past.
Me
drei is offline   Reply With Quote
Old 07-28-2005, 03:16 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Reverse is the only gear where you actually move the sprocket. Your clutch piston rod might need adjustment, check the fluidlevel and if its low, add some and bleed it.
Old 07-28-2005, 05:36 PM   #3 (permalink)
drei's Avatar
thanks Flashmn...i was sure u were gonna reply...how do i check the fluid level, and then bleed, i know nothing about transmissions...
Me
Old 07-28-2005, 11:45 PM   #4 (permalink)
View bob022004's Photo Gallery
that bleed is tougher than doing the brakes....nice bends in the lines trap the air
1988 Toyota Corolla GT-S
16V 4A-GE
ACT Stage 1 clutch
bob022004 is offline   Reply With Quote
Old 07-30-2005, 11:57 PM   #5 (permalink)
dirt666's Avatar
View dirt666's Photo Gallery
I found that when you unhook the speedometer, it seemed to make my clutch work better. Why not try that first. Good luck.
dirt666 is offline   Reply With Quote
Old 07-31-2005, 12:01 AM   #6 (permalink)
'10 XRS (05 & 09 XRS RIP)
rolla-XRS's Avatar
Gameroom cash: $105560
View rolla-XRS's Photo Gallery
rolla-XRS is offline   Reply With Quote
Old 07-31-2005, 01:05 AM   #7 (permalink)
View Jester8759's Photo Gallery
About the reverse thing, I had the same problem on my old car and then I read in a thread to bump it into third first then reverse (something about slowing the gear down so I could go into reverse or something) and I started doing that and have never had a problem since. I do the same thing in my new corolla just out of habit
Jester8759 is offline   Reply With Quote
Old 08-12-2005, 07:34 PM   #8 (permalink)
dirt666's Avatar
actually what I find works real well when the car is stubborn to get into reverse gear is to just shut the car off, select reverse and then start it with the clutch in. You might also want to check the radiator coolant level to ensure that the clutch is getting cooled enough. Good luck.
Old 11-01-2006, 03:40 AM   #9 (permalink)
View ndestree's Photo Gallery
Actually the reverse gear is opposite and you need to slow it down the fastest way and easyiest is to just let the clutch out half way then put it back in then it will go right into reverse.
ndestree is offline   Reply With Quote
Old 11-01-2006, 06:51 AM   #10 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
You can buy a self bleeder for less than $10.00 US. and bleed it in about 5 minutes. Check your clutch master cylinder and make sure you have the proper fluid level when you finish bleeding it. I would check my clutch pedal adjustment too.
If you have a problem putting the gearshifter in reverse on the first try then do this: take your foot off the clutch pedal push it down again with a steady pressure and try to put it in reverse. Dont slam it, just apply a little pressure.
diver9000 is offline   Reply With Quote
Old 11-01-2006, 02:23 PM   #11 (permalink)
Gameroom cash: $134355
um, those are COMPLETELY unrelated
Old 11-01-2006, 02:37 PM   #12 (permalink)
The TN Member
View punter's Photo Gallery
I think it would be best if you stop offering advice.
If you don't know don't make shit up.
K thx bye.
It's pretty normal for cars to be a little hard to get into reverse, just make sure your not rolling when you try.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-01-2006, 05:35 PM   #13 (permalink)
[/quote]
wow, didn't even SEE this one.... quite hilarious....
first off, if you have problems with the reverse (which all C series trans i've owned do) then just leave it in neutral, release the clutch, push it back in and it should slide into gear....
if you have a problem getting it into 1st gear when stopped, that's when you want to start checking the clutch fluid levels and/or for leaks (well, it's always good to check the levels, and if low check for leaks).....
as for the 'radiator coolant level'.... wow.... that's an interesting one..... heat on a clutch is either from a lot of slipping the clutch (ie, new driver.. causing pre-mature wearing) or simply heat passing from the crank to the flywheel.... etc...
(the only thing that doesn't have contact with the radiator fluid, but CAN affect it.... so far that i've found... is the ignitor within the distributor.... and I only found this out once i did the 4age swap using the 4afe electronics.... i burned through ignitors if they weren't well cooled... and the 4afe dizzy just happens to be sitting next to a main coolant passage)
Old 11-01-2006, 08:09 PM   #14 (permalink)
diver9000's Avatar
[quote=punter]I think it would be best if you stop offering advice.
K thx bye.
OUCH! I DIDNT SEE THAT ONE COMING, THATS FOR SURE.
Old 11-01-2006, 08:28 PM   #15 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
I've had that reverse problem pop up occasionally on every stick shift car I've ever owned (6 in total so far). Generally, reverse gear isn't synchronised, but apparently on some GM transmissions it is oddly enough. I find that putting the car into neutral, letting the clutch out for a second then shifting into reverse helps. If you put it into reverse with the clutch pedal pressed down and it crunches then that might indicate a problem. My 88 Corolla wagon does that sometimes.
Infinitrium is offline   Reply With Quote
