Brake Lines?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2005, 06:37 PM   #1 (permalink)
View ltdinc1's Photo Gallery
Brake Lines??
Ok so I have a 94 Toyota Corolla and my brake lines are rusted through... so i need to know the lenght of the two that head towards the back of the car i dont believe my car has abs (if that matters) and i know they are 3/16th in diameter any help would be greatly appreciated thank you
ltdinc1 is offline   Reply With Quote
Old 07-29-2005, 07:29 AM   #2 (permalink)
View stubborn1's Photo Gallery
Your best bet would be removing the existing lines and measuring the total length. After you know the length, you can head to the parts store and buy the correct length of brake line you are going to need.
Make sure to use a tube bender to match the bends of the existing line. If you try bending the lines without using a bender, you can crease the line causing a weak point. These points can fail under the high pressure of the hydraulic fluid in the brake system = no brakes. You may also need a flare tool if you need to cut the brake line to length.
stubborn1 is offline   Reply With Quote
Old 08-01-2005, 08:06 AM   #3 (permalink)
if anyone has recently swapped thier brake lines and know what length they are that would be great
