your 4afe has 4 valves per cylinder..... the head design is what's called a slave cam. You have one cam that runs on the timing belt. Under the valve cover, each cam has a cog bolted to it which mesh with one another. This means that the cams actually run in opposite directions. Because of this, the cams are also closer together and have a narrower inlet for the valves. A twin cam (4age) has 2 cam gears on the timing belt, cams run in the same direction and have a wider stance from one another. Also, the 4age crank is stronger, has an 8 bolt crank (versus a 4afe 6 bolt crank).... the 4age crank is forged..... has stronger rods, and higher compression. The smallport (90-91) also has hookups in the block for oil squirters... the GTS came with an oil cooler, none of the other corolla's in the US came with them.
