Originally Posted by Hook
^^^ u don't.....there's no tranny fluid in manual cars, only gear oil which is used only for lubrication
Yeah, we have a mixture of replies here from people who have automatics and manuals and it's a bit confusing. The original post looks like he was asking about a manual (5-speed).
If you have a manual you have gear oil. On my car (and probably lots of others) you check it when the car is off the ground by undoing a plug on the gearbox and sticking your finger in the hole. The maintenance interval is in the owner's manual but this stuff can last a really long time unless you have a leak. It's one of those things that theoretically needs changing but if you don't then it may almost last the life of the car.
If you have an automatic you have transmission fluid and somebody already talked about that. This needs more frequent checking and replacement and if you don't you're asking for major trouble$. For my car it's every 20,000 miles and you check the level with a separate dipstick. If you pull out a dipstick and see red fluid then it's probably the transmission fluid (if you know it's transmission fluid and it looks like oil, you better not drive it another mile, and expect to spend over two grand at least).
1981 Corolla Wagon, 5-speed, 159k miles-- my winter wheels
1981 Corolla Wagon, AT, 125k miles-- my summer wheels
** I replaced a horn. Isn't that mod. enough?
