I know with the 1.6 4age...should be the same for all a serie engine.
You just need a 10mm wrench (with the round grip) to loosen up the belt tentionner.
Than you just need a budy to push the tentionner as far away while you try to remove the belt for the top gears.
Then you use a 17mm rachet (probably with a force bar)and unbolt the cranck pulley.
Try not moving the pulley while unbolting it or your timing will be f***.
My trick is tu put a big screwdriver through the pulley tu make sure is block and can't turn while I'm removing the 17mm bolt.
Then you just have to take the pulley with your both hands and pull little by little, don't give a big pull or you'll end up with pulley marks on the face!
installation is opposite of removing! (took the last sentence from a haynes manual
