Short Ram Intake - Kills Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2005, 12:56 AM   #1 (permalink)
View RGTAsheron's Photo Gallery
Unhappy Short Ram Intake - Kills Engine
Hello,
I recently installed an SRI on my 04 Corolla CE. After installation upon starting the car the engine would catch then immediatly die off while sending shudders through the body of the car. I swapped back to stock and it worked fine again.
Does anyone know what kind of a screw up could have caused symptoms such as I have described?
Thank you,
Asheron
RGTAsheron is offline   Reply With Quote
Old 08-06-2005, 01:12 AM   #2 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
maybe there is something stuck in the intake pipe that is restricting the engine from getting air?
this happened to me once while i was swapping out my intakes, hehehe
had a bag in the pipe and didnt know it, the engine died right when i started cause it was suffocating.
Reminder to all: Bags are not toys, they may cause suffocation. Please keep away from children and cars.
WhiteRabbit is offline   Reply With Quote
Old 08-06-2005, 09:21 AM   #3 (permalink)
Negative. I have checked everything. The tube, and pipe, (and filter) are all clean.
Old 08-06-2005, 05:49 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $250421
View REN69's Photo Gallery
Try unplugging the battery to reset the ECU, maybe the ECU has a bad reading.
Old 08-06-2005, 07:56 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Possibly the breather hose or leak on AFM.
Old 08-06-2005, 08:19 PM   #6 (permalink)
4u2nv
kasimmmmm's Avatar
View kasimmmmm's Photo Gallery
sounds like a leak to me..
kasimmmmm is offline   Reply With Quote
Old 08-07-2005, 09:24 AM   #7 (permalink)
What is the AFM? Is that the sensor that I move?
When I installed it the battery was out for about an hour while I made absolutely certain everything was in the proper place. I'm thinking that its something either with a bad seal on the tube as you guys mentioned. (I'm going to test that tonight by using the tube on stock setup) Or with the sensor.
How would I fix a leak?
Old 08-07-2005, 04:20 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
You removed the AFM sensor? No wonder its not working
Old 08-07-2005, 04:48 PM   #9 (permalink)
KDM is in
REN69's Avatar
wait... was the intake you bought meant for a 04 Corolla or was it a cheap "ebay" intake?? if it was meant for the Corolla it would have told you what to keep and what to take off.. but I'm guessing its not.. in which case you might have removed the AFM thinking it wasn't needed.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-08-2005, 08:25 PM   #10 (permalink)
No I removed the AFM and moved it into the SRI . I've been, in a general way, following this tutorial: http://www.diynetwork.com/diy/ab_par...081609,00.html for most of my work.
This is the one I purchased:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7987605293
The final intake had the Air flow sensor in it and plugged in and a hose coming out of it which hooked onto the same place the similar hose from stock did.
Old 08-09-2005, 11:41 AM   #11 (permalink)
View polo708's Photo Gallery
thats weird, I have a SRI on mine (AEM) and it's fine... It's referred to as a MAF sensor (mass air flow) and it's very picky. Disconnect the battery, reconnect and let it idle for about 5-10 minutes without any accessories on.
2004 Supercharged Corolla S
polo708 is offline   Reply With Quote
Old 08-09-2005, 09:09 PM   #12 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
they usually suggest removing the eci fuse for 15+ minutes(instead of disconnecting ground). then idle for 15 with nothing on then for another 5 with the ac running
adsaba1969 is offline   Reply With Quote
Old 08-10-2005, 08:29 AM   #13 (permalink)
KDM is in
REN69's Avatar
Ok.. I know your engine is different from mine but they're both AFM sensored, so this is what it basically should look like. Except that instead of having a black rubber intake, you should have your metal intake, the AFM, then the filter. (don't worry about the "right there" part, I took this picture a while ago to show someone where the idle screw was located on a 4AGE)
Old 08-10-2005, 07:50 PM   #14 (permalink)
Thank you for the picture
@adsaba1969
When you say remove that fuse... The car won't start without it will it? (I'll give it a shot as soon as I can). But according to your directions, I do the install, reseat the battery, remove that fuse, then try and start?
Old 08-11-2005, 05:32 PM   #15 (permalink)
Do you know what the manual calls the ECI fuse?
