Removing Intake manifold/ITBs - 20v - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2005, 01:46 AM   #1 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Has anyone done this? Do you have to remove the ITB's before you remove the entire manifold? The reason i'm asking is because i am completely stumped. I have to remove the intake manifold so i can get to the knock sensor, but i cant figure out how
Dont have an engine hoist either, so taking the engine out is not an option, have to work in a tight space
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-06-2005, 08:42 AM   #2 (permalink)
Country Hick
thespud's Avatar
n/m... I got it. Changed the knock sensor and it still didnt fix the un-diagnosable engine light
Old 08-06-2005, 09:31 AM   #3 (permalink)
NIGHT STALKER
throwback's Avatar
View throwback's Photo Gallery
well you should drain the battery by turning the lights on for about a good 30 sec, pop the hood, disconnect positve terminal first, then the negative, open the fuse box nearest to your battery then pull out the ecu fuse ( if you dont kno wich it, should say under the cap EFI thats the one ) leave it out for about 30 sec, then put it back in cover fuse box again and connect the battey terminals ( positive first negative after ) start the car and if your car doesnt have a problem the the check engine light wont turn on but if it does than im srry i couldnt help you. PEACE
NIGHT STALKER
throwback is offline   Reply With Quote
Old 08-06-2005, 10:55 AM   #4 (permalink)
Country Hick
thespud's Avatar
^ I've tried that many of times... Trust me, I've changed the vacum lines, the Idle Speed Sensor, the Throttle Position Sensor, the oxygen sensor, the spark plugsa nd leads AND the distributor cap. And the car is still running rich with the CEL backwards (As in, CEL off when ignition switched to on, then turns on when engine is running.)
And the Diagnosis check doesnt work Otherwise it would have been a cheap fix.
Old 08-07-2005, 12:08 PM   #5 (permalink)
NIGHT STALKER
throwback's Avatar
man srry to hear that, hope you find out the problem and is easy to fix
NIGHT STALKER
