idle current drawn from battery? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2005, 10:53 AM   #1 (permalink)
View -=carlos=-'s Photo Gallery
Hi all, could anyone tell me how much current I can expect to see drawn from the battery of my M reg 1.3 Toyota Corolla (UK) at idle?
I charged the battery yesterday and the car wont start again today with a flat battery, i've just charged it today and want to test how much current is being sunk upon connection to confirm what i'm dealing with.
Thanks.
-=carlos=- is offline   Reply With Quote
Old 08-07-2005, 11:14 AM   #2 (permalink)
At idle I don't mean with the engine running btw, I mean at an idle state of ignition and nothing on.
If I were to have to guess I'd say a couple of hundred milli amps but if anyone knows for sure that'd be good.
Old 08-07-2005, 12:40 PM   #3 (permalink)
foodaa's Avatar
View foodaa's Photo Gallery
Key On Engine Off, 200 mA parasitic draw is a bit much. Less than 100 mA is ideal. Ofcourse newer cars tend to have more computers and electronic junk and will tend to draw more current. If you are trying to locate/isolate a circuit that you think is drawing too much current, start pulling fuses one at a time. If the parasitic draw disappears, then you found the suspect circuit.
foodaa is offline   Reply With Quote
Old 08-07-2005, 05:09 PM   #4 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
interesting...on the odd occasion that I have to remove my battery poles to get work done, it sparks slightly when I'm reconnecting it...even with the doors closed and all devices switched off
so if I want to check this, I'm putting my ammeter in series with the +ve battery pole and the main fuses, putting the keey to the ACC position and pulling fuses one by one until I isolate the source of excessive parasitic draw? is that correct?
Hook is offline   Reply With Quote
Old 08-07-2005, 07:05 PM   #5 (permalink)
View karazy's Photo Gallery
Leave the key out. You're looking for power loss when the car is off. Normal drainage from the clock, radio and sensors are there all the time, but you would be looking for something that shouldn't be there.
karazy is offline   Reply With Quote
Old 08-08-2005, 08:55 AM   #6 (permalink)
Hook's Avatar
cool tnx the only draw should be from the radio then, cuz I'm carb'd and there's no clock
Old 08-08-2005, 09:28 AM   #7 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
^^ And Immobiliser (or factory VSS) if fitted...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-08-2005, 02:00 PM   #8 (permalink)
Hook's Avatar
okie....got my battery and charging system checked 2day and I got the thumbs up...everything works gr8
the tech suggested that the small spark might've been coming from the amplifier's internal power supply's caapacitors charging....once they're charged at full, they don't draw any current and there's no spark when I reconnect the battery pole
Old 08-08-2005, 03:29 PM   #9 (permalink)
OK as it turns out it was just a duff battery that was playing me around. The new one sinks about 20mA with the key off just to let anyone know.
