Reverse gear shaking the engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2005, 08:07 PM   #1 (permalink)
View aldwinenriquez's Photo Gallery
Just wanna know why is my engine is shaking when im on the reverse gear.Actually im not sure if its really the engine but something gets noisy at the front?What could it be?Im wondering if I need to tune-up the engine or change the engine supports..Any other ideas?
aldwinenriquez is offline   Reply With Quote
Old 08-07-2005, 08:12 PM   #2 (permalink)
Foul Weather Drifter
View SpeedballTrix's Photo Gallery
Does it do it in first if you are light on the clutch?
If so, its the clutch slipping.
If it's ONLY reverse, then it must be a tranny (or shifter) problem.
Have you been doing reverse doughnuts?
They DESTROY automatics and arent good for manuals either because of the weak syncro.
Does the shifter shake when it happens?
If it is, you might have a problem with the reverse gate.
Saw it happen to a jetta. It was funny
SpeedballTrix is offline   Reply With Quote
Old 08-07-2005, 08:46 PM   #3 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Does it horribly shake? Does it do it in drive, too, while stopped?
Cars get shaky and noisy and start rattling after a few years, so its only normal.
Mine was doing that too and I found it was a cable hitting against the hood from the bottom. It could be just some interior panels shaking.
I guess its not worth it to change engine mounts or anything.
Try to locate the source of the noise, or just drive around with it and it might stop doing that (happens to my car all the time).
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 08-07-2005, 09:49 PM   #4 (permalink)
View rustygti's Photo Gallery
There are very few gearboxes anywhere in the world that have a synchro on reverse... My car does exactly the same thing, and it is the clutch slipping... why it doesnt happen in any forward gears has me stuffed????
rustygti is offline   Reply With Quote
Old 08-07-2005, 10:33 PM   #5 (permalink)
If it doesnt happen in the other gears it cant be the clutch slipping.
The same clutch does the same thing everytime you push in the clutch pedal.
Old 08-08-2005, 04:24 AM   #6 (permalink)
it only happens on reverse when the clutch is halfly extended. It doesn't happen when the clutch is not totally released.
Old 08-08-2005, 02:29 PM   #7 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
in our 85 sr5 it would violently shake the car and shifter when you started engaging 1st gear, but once the car gained momentum it would stop. it also shook in second gear slightly when engaging but non in the other gears. what caused that?
01loadedLE is offline   Reply With Quote
