Idle fluxuation on ae86 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2005, 08:11 PM   #1 (permalink)
View flygts's Photo Gallery
Canada Idle fluxuation on ae86
I have an idling problem noone I know can figure out. my car idles at 10000rpm and goes to 1300 evry couple seconds.
This is an on and off problem.
Does anyanyone have a waterpump for an ae86 manual fan.?????
flygts is offline   Reply With Quote
Old 08-09-2005, 08:26 PM   #2 (permalink)
Rotor > Piston
powderblue91's Avatar
View powderblue91's Photo Gallery
10000 damn that's high!
haha. anyway, check for vac leaks.
-Eric
1991 SV21 DX - The slow
1990 FC3S GXL - The go
powderblue91 is offline   Reply With Quote
Old 08-09-2005, 08:35 PM   #3 (permalink)
View Twincam16's Photo Gallery
Check you coolant level.
Twincam16 is offline   Reply With Quote
Old 08-09-2005, 08:43 PM   #4 (permalink)
86 is one who drifts
View DRIFTASSAULT's Photo Gallery
i would also say check coolant and vacuum leaks
Salt ruins cars
I'm a jitbag. Whats that?
DRIFTASSAULT is offline   Reply With Quote
Old 08-10-2005, 07:25 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Try this.. My car used to go from 1000-1500 up and down up and down everytime I would come to a stop or at idle. This happened first when I got my thermostat and radiator replaced, and again after I got the throttle cleaned out at Mr Lube, this is how I finally got rid of the problem:
Find your idle adjuster screw, raise the RPMs on the car by going counter-clockwise until the RPMs finally stay at a steady 1500rpm for example. Wait about 5-10 seconds, then move the idle screw clockwise until the RPMs drop to about 900-1000 RPM and this will do the trick.
If this doesn't work, then you might have a different problem.
Old 08-13-2005, 06:38 PM   #6 (permalink)
View BIMBOTRD's Photo Gallery
The Idle Control Valve Is Probably Going Bad, I Recommed Check For Any Air Leaks And Coolant Level, Termostat But Im Pretty Sure That It Could Be The Idle Valve
BIMBOTRD is offline   Reply With Quote
