Who has upgraded their rear speakers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2005, 12:38 AM   #1 (permalink)
In love with boost
emiliorescigno's Avatar
View emiliorescigno's Photo Gallery
AE92 Who has upgraded their rear speakers?
I just made an attempt today at installing Infinty Kappa 52.7i's (5 1/4s) in the rear deck of my 1991 Corolla SR5. I managed to strip down the rear deck of the speakers, carpet, light, etc. However, my kappas do not fit inside the plastic mounting the original speakers were screwed to. Who here has upgraded their rear speakers in their AE92 and how did you do it? All stories welcome and the more detail the better! Thanks!
emiliorescigno is offline   Reply With Quote
Old 08-11-2005, 05:38 AM   #2 (permalink)
View gasman's Photo Gallery
get some spacers. very easy to install if you dont mind having them sticking up, you barely notice them anyway. i did mine for 6x9's but round ones should be just as easy. or you can cut into the metal in the parcel tray but you can run into some trouble with the law here where i am by doing that.
Brake-Down Shift-Turn
gasman is offline   Reply With Quote
Old 08-11-2005, 06:29 AM   #3 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
In the sr5 there is little space at the back so a box is hard to put in. I just bought standard 6x9 mounts for a audio shop then I cut into the cardboard tray and used speaker mounting clips to screw into. I was able to fit 6x9 in the rear. But the mounts were also to big so i had to cut them and the plastic cover for the trunk release to get these big suckers in.
Liter is offline   Reply With Quote
Old 08-11-2005, 06:54 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
SR5s are easier to upgrade than the GTS speakers.. the rears are a pain in the ASS! since the rear covers actually clip on to the speaker itself. it's one of those things that I would love to smack the dumbass engineer that thought of this one..
Old 08-11-2005, 06:57 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
On my tercel I mounted a board to underside of speaker shelf and mounted 6x9's to the board. I have an acoustcally transparent material on top of the shelf so no speakers show. Looks very stock until trunk is opened.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-11-2005, 08:07 AM   #6 (permalink)
sound like stealth
got a pic?
Old 08-11-2005, 08:41 AM   #7 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I cut out the 6" holes in the metal to fit 6x9's in my AE102. Just used a dremel and cut to fit, then installed the oem rear deck panel over them.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 08-11-2005, 11:01 AM   #8 (permalink)
In love with boost
Gasman, what type of spacer did you use? Just a basic 6x9 stand? Where did you attach it to the car?
Old 08-11-2005, 12:45 PM   #9 (permalink)
In love with boost
REN, the speaker covers on mine clip into the speakers as well, us SR5 owners are equally screwed .
Old 08-11-2005, 01:37 PM   #10 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
got my custom pods on the front doors and placed the tweets in the A-pillars which eliminated the need for rear speakers
Hook is offline   Reply With Quote
Old 08-11-2005, 05:38 PM   #11 (permalink)
Foul Weather Drifter
View SpeedballTrix's Photo Gallery
You should always be sure to make sure speakers fit before you buy them, unless you are prepared to fab some mounts.
Its not too hard, but it's easier just to buy the right size speakers.
you can use this to check compatibility.
This is one of the fosgates in the back of my AE91.
It fits perfectly in the stock location.
It fits under the stock enclosure with no problem.
SpeedballTrix is offline   Reply With Quote
Old 08-11-2005, 11:00 PM   #12 (permalink)
i got my spacers second hand and was custom made for the other guy.
i attached buy using screws and just screwed it on from the underside of the "flimsy" parcel tray
Old 08-12-2005, 07:00 AM   #13 (permalink)
KDM is in
REN69's Avatar
Fuk this.. I'm getting me a dremel.. I'm sick of OEM speakers on the back.. I'm thinking of installing dual 8" subs on the back.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-12-2005, 09:38 AM   #14 (permalink)
You shouldnt eliminate the rear mids.
Just make sure you get the right size speakers.
I have done several installs in friends' cars, and one snafoo aside, they always take less than 30 minutes for speaker swaps and about 1-2 hours for installs including subs and an amplifier (since you usually need to run wires).
As long as you do your homework beforehand, its simple.
Ren: You're rears are 5.25" and your fronts are 4".
Rears -
http://electronics.listings.ebay.com...stQQsofocusZpf
Fronts -
You can also just put a box in the trunk, instead of making custom floating mounts.
I know for a fact that a double 12" box will fit in the trunk of a '90 AE91 (since i made one for my car) so it will probably fit in yours as well.
You will get much better sound if you retain the stock 4 speaker locations and add a sub box.
Old 08-12-2005, 03:10 PM   #15 (permalink)
In love with boost
Speedball, you have a sedan not a coupe, the sedans have normal 5 1/4" mountings in the back like you've demonstrated. However, the coupes have a very unorthodox mounting method, that is slightly smaller than a 5 1/4 but no compatability website knows of it (go check cardomain or crutchfield). Even if the 5 1/4s were able to be stuffed into the mouting bracket in the coupes, the speaker covers over them would not mount in because the clips that hold the speaker covers on are inside the stock speaker, so it's a double-failure. REN and I both thought 5 1/4s thinking they would fit and have learned otherwise. The only way to make everything work well is to make some sort of custom mounting....so why not 6x9s right?
