valve cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2005, 10:49 PM   #1 (permalink)
95 COROLLA's Avatar
View 95 COROLLA's Photo Gallery
valve cover
hey i want to take my valve cover off to clean it up and make it look new do you guys have any tips i should know ?
thanks
95 COROLLA is offline   Reply With Quote
Old 08-11-2005, 11:08 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Do NOT use purple power or any purple equivilent as it will be very ugly afterwards.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-11-2005, 11:22 PM   #3 (permalink)
95 COROLLA's Avatar
why? and what's purple power anyways?
Old 08-12-2005, 06:55 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
They're cleaners.. I was told to use that green cleaner on engine bays.. can't remember the name.
Old 08-12-2005, 07:04 AM   #5 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Simple Green or any degreaser would be your best bet.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 08-12-2005, 09:24 AM   #6 (permalink)
95 COROLLA's Avatar
thanks but what about when i take it off? will oil leak everywhere? will i have to replace the o-ring or gasket? and if i do how much is a new o-ring and gasket?
Old 08-12-2005, 09:46 AM   #7 (permalink)
Master Taco Ninja
XxaltezzaxX's Avatar
View XxaltezzaxX's Photo Gallery
while it is off you might as well change it they are not expensive parts. i used 2+2 to clean my vavle cover and scrubed it with a tooth brush to get to the hard parts. better to change the gasket now then to have to pull everthing off later
XxaltezzaxX is offline   Reply With Quote
Old 08-13-2005, 08:49 AM   #8 (permalink)
View BIMBOTRD's Photo Gallery
Go To Auto Part Store And Get Brake Cleaner, This Is A Cleaner That Will Clean Well And Leave No Residue Because It Drys By It Self, It's A Can, Now To Removeds All You Need Is A10mm And A Set Of Pliers And A Big Screwdriver To Help Pull It Out, Be Careful That When You Pry To Removed Do Not Brake Any Sensors
BIMBOTRD is offline   Reply With Quote
Old 08-13-2005, 08:52 AM   #9 (permalink)
THE CLEANER ONLY COST LIKE 1 OR 2 DOLLARS AND WITH TWO CANS OYU SHOULD BE FINE, ALOS YES IS A GOOD IDEA TO REPLACED THE GASKET IF IT FEELS HARD, IF YOU REPLACE THE GASKET, PUT A LITTLE BIT OF SILYCONE IN THE CAMSHAFT CAP THE OUTER ONES, THIS WILL PREVENT THE CAR FROM LEAKING IN THE SHARP CORNERS
