2000 corolla using oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 12:00 PM   #1 (permalink)
View whitcre's Photo Gallery
i bought a 2000 corolla with 50,000 miles. it is using about 1/2 qt of oil every 300-400 miles. anyone have this problem or know what may be causing it
whitcre is offline   Reply With Quote
Old 08-13-2005, 12:37 PM   #2 (permalink)
foodaa's Avatar
View foodaa's Photo Gallery
Look for leaks. Whats the color of the exhause smoke?
foodaa is offline   Reply With Quote
Old 08-13-2005, 02:35 PM   #3 (permalink)
no smoke, no leaks
Old 08-13-2005, 08:33 PM   #4 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
take it to the dealer asap. possible engine sludge/bad piston rings/seals. should be under warranty but get ready for a battle, especially if you dont have prior records/receipts of oil changes from toyota dealers only. good luck.
01loadedLE is offline   Reply With Quote
Old 08-13-2005, 08:52 PM   #5 (permalink)
View EngineerBoo's Photo Gallery
No smoke? That's good, but scary, too.
Check all the places where oil can leak from....oil filter, drain plug, seal around drain pan, gaskets on headers on the engine.
Definately have a mechanic check it out SOON.
Good luck!
Boo
EngineerBoo is offline   Reply With Quote
Old 09-13-2005, 07:29 PM   #6 (permalink)
View steve97's Photo Gallery
Parents 94 Corolla with a 1.8 motor is also losing oil at an alarming rate. Will jump under there this weekend to see if I see it dripping, but no drips on the garage floor, so probably burning it. Looked at Edmonds forum, and seen quite a few other Corolla owners commenting about mysteriously losing lots of oil from their Corolla and no smoke or anything.
steve97 is offline   Reply With Quote
Old 10-04-2005, 10:31 PM   #7 (permalink)
View snspar's Photo Gallery
I have smililar issue. No leak. chaning oil for every 700 to 800 miles. Can any one suggest......
snspar is offline   Reply With Quote
Old 10-05-2005, 07:20 AM   #8 (permalink)
View petec's Photo Gallery
Try replacing the PVC valve (with OEM, not aftermarket). A bad one can cause oil usage.
petec is offline   Reply With Quote
Old 10-05-2005, 09:30 PM   #9 (permalink)
View cashcrazy's Photo Gallery
anyone have a pic of where the PCV valve is located on these models??
cashcrazy is offline   Reply With Quote
Old 12-19-2006, 05:57 AM   #10 (permalink)
View RealGomer's Photo Gallery
PCV Replacement
Remove the plastic valve cover. In the back of the engine, you will see the PCv sticking out of the valve head. Be very careful as the head is aluminum. If the engine has sort of mileage, you'll need to "break" it loose. Do buy the replacement from a Toyota dealer. Mine cost a whopping $6, less than an aftermarket. In my opinion it's woth getting a shop manual from Autozone or Pep Boys. The instruction are very detailed and with good pictures.
RealGomer is offline   Reply With Quote
