difference between Toyota oil filters - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 01:29 PM   #1 (permalink)
JMR
View JMR's Photo Gallery
Can anyone tell me the difference between Toyota oil filter pn# 90915-YZZA2 and pn# 90915-YZZF2. The only thing I can find on the net is that the F2 is used on the Scion line. Any ideas?
JMR is offline   Reply With Quote
Old 08-13-2005, 01:58 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
I beleive one is a japaneese filter and the other is an american filter. The japaneese one is a little bit taller but both will work the same because the threads, and seal and holes are all the same on it.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 08-13-2005, 03:42 PM   #3 (permalink)
Official Acura Troll
View 02RSX90camry's Photo Gallery
i thought tehy switched from A2 to F2, so A2's are no longer available. Just changed the part number i think.
02RSX90camry is offline   Reply With Quote
Old 08-13-2005, 04:28 PM   #4 (permalink)
SCCA Tech Services
Yeah I think you are right they superseeded the part number now.
Brian Harmer
Old 08-13-2005, 06:06 PM   #5 (permalink)
View BIMBOTRD's Photo Gallery
Is The Same Filter The Difference Is Just That The F2 Is A New Version And It Comes With Grease In The Oil Filter Seal To Help Sealing
BIMBOTRD is offline   Reply With Quote
Old 08-13-2005, 06:19 PM   #6 (permalink)
The Denser The Air The Bigger The Explotion Is In The Combustion Chamber For This Reason You Get More Hp
Old 08-13-2005, 06:31 PM   #7 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
When I checked with Toyota last, the shorter filter of the two originals was replaced with an even smaller filter.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 08-13-2005, 06:33 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
those cheapskates, making you pay the same for less
Old 08-13-2005, 10:05 PM   #9 (permalink)
JMR
Hmmm. That's interesting. My 05 has 21,000 miles on it now. I've always been a been disturbed by the amount of topend noise on initial cranking. Howerver, after the oil change today, it's not doing it anymore so I checked my receipt. They changed to the F2 filter. Obviously something is different. Since the filter is mounted vertically, I couldn't understand why the problem would exist. Thanks.
Old 11-20-2005, 02:55 PM   #10 (permalink)
View forrester's Photo Gallery
filter difference
There is little, if any difference in the size of the yzza2 vs the yzzf2 (the a2 box is slightly larger). The a2 is made in the US, the f2 in Thailand. The manufacturer of the a2 is not stated; the f2 is made by Denso and is so marked on the filter.
forrester is offline   Reply With Quote
