Loud sound when shift into reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2005, 01:26 AM   #1 (permalink)
View pk604's Photo Gallery
I just got a 2004 corolla with 31K miles on it.
When I turn it on in the morning and shift into reverse, there is a loud sound as it switches gear into reverse.
Does anyone know what might be causing this? I am suspecting that when the car is left overnight, the engine has a high rpm when first started, then the rpm would drop after it warms up.
but I don't know if this is normal or not. thanks for your help.
pk604 is offline   Reply With Quote
Old 08-14-2005, 06:14 AM   #2 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
is your car manual or auto? Can you give a description of the noise?
it should idle higher at 1st then drop down to 600-800, somewhere in that range
adsaba1969 is offline   Reply With Quote
Old 08-14-2005, 10:20 AM   #3 (permalink)
5speed manual. corolla S.
Yes, it idles around 1400-1500, then drops once it warms up. When I put it into reverse at or around this rpm, it makes a noticeable clanking noise - something like when you park up or downhill with an automatic and you try to shift.
I just wanted to know if this is normal.
Old 08-14-2005, 10:23 AM   #4 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
my friends toyota truck does it but its like 10 years old. and it is a manual. does it take some force to shift it into reverse too or does it just shift normally and make a sound?
nodrogkam is offline   Reply With Quote
Old 08-14-2005, 10:30 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Does the noise occur when moving the shifter into gear or when you release the clutch?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-14-2005, 10:33 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
a noise is normal, because you're moving the sprocket into place, reverse sprocket moves, others do not.
Old 08-14-2005, 01:07 PM   #7 (permalink)
Whine connoisseur
try this....start it up, make sure the car isn't moving, put it in 1st gear then go to reverse, should go in smoothly.
Old 08-14-2005, 02:58 PM   #8 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
sounds like your clutch isn't engaged enough. Are you pushing the clutch to the floor when going into reverse? My car does the EXACT same thing, and I need a new clutch.
Bryn-
SR5_4WD is offline   Reply With Quote
Old 08-14-2005, 03:36 PM   #9 (permalink)
Whine connoisseur
i hope he doesn't need a new clutch with 31K. If so he would need an automatic before a clutch
Old 08-15-2005, 02:47 PM   #10 (permalink)
'96 Rolla DX
Hahah yeah, that's why I want to hear what the solution was!
Bryn-
Old 08-15-2005, 04:09 PM   #11 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Well.. if the car was previously owned by a 5spd newb.. chances are that clutch or the synchros are deader than a skunk on the highway.
Old 08-23-2005, 02:35 PM   #12 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
noise
hi,
my 1993 corolla has the same problem. When i asked on of my friend he said that i need to put some cleaning liquid (dont remember exactly the name) when the gas tank is full. This helps to inject sufficient amount of fuel into the engine ( ibelive). I havent tried it but i will let u know the results after i do that.
celica2004.
celica2004 is offline   Reply With Quote
Old 08-24-2005, 01:00 AM   #13 (permalink)
View jbroda's Photo Gallery
My '99 Corolla has been doing it since I bought it new. I think it's normal.
To avoid the noise/clunking, I put it in 1st gear first, and then in reverse.
jbroda is offline   Reply With Quote
