Here's my problem....
I have a Silvertop engine running with a Blacktop ECU. Everything is working OK but I was looking at the wiring for the O2 sensor and found that on the Silvertop diagram the four wires to the sensor are as follows....
+B= Battery and +B on Check Connector
HT= Pin#14 on 26 Pin Connector
OX= Pin#6 on 16 Pin Connector and OX1 on Check Connector
OXL1= Pin#13 on 16 Pin Connector
These are fine except that I am using a Blacktop ECU. The Pin outs for it are as follows....
HT= Pin#8 on 26 Pin Connector
OXL1= ??????
Does anyone know where the OXL1 wire goes to on the Blacktop ECU?
