engine timing with f/i - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2005, 02:46 PM   #1 (permalink)
View igorien2k's Photo Gallery
Hi everyone,
I drive a 98 corolla, but this question pertains more to ECUs then the corolla in specific.
My ECU is a MAP-based, and i wanted to run a 2-bar MAP sensor and 2x size injectors for fuel management with turbo. Here's a Honda forum link that describes approximately how this should work(and yes, it has been tried successfully)
http://www.honda-tech.com/zerothread?id=531705&page=1
The only thing that concerns me with this setup is the engine timing, because my engine's CR is 10:1. My car comes with a knock sensor stock. If i rewire the ECU to stay in closed loop mode, will it be able to retard timing enough to avoid knock? i just want to see if anyone knows approximately how many degrees of timing you can lose with the stock ECU setup? I tried asking this on other forums, but wasnt able to get any clear answers.
-Igor
igorien2k is offline   Reply With Quote
