Dumb question... removal of headlight bulb on 99 rolla. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2005, 03:45 PM   #1 (permalink)
View gspatta@worldne's Photo Gallery
Ok, I've searched but did not find exactly what I needed. Question.
On a 99 rolla. To replace headlight bulbs I... Pull stuff thats in the way (fuse box and the battery). Pull the rubber "boot" off.
Then the manual says to take clip off and basically replace bulb. My clip seems to be held by some little screws. Take them off ? How does the clip come off ? Can I reuse the clip ? Twist bulb out or does it pop right out ?
Thanks, George
gspatta@worldne is offline   Reply With Quote
Old 08-17-2005, 03:34 AM   #2 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
im not so sure about your car.. but most of the car that has a little clip holdin the bulb has a screw on one side and the other side is held in by a clip... u just gotta play around with it and get the other side off (without the screw) and then your bulb should b free to come out
KnightX_AE86 is offline   Reply With Quote
Old 08-17-2005, 06:38 PM   #3 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
If it's anything like mine, there should be a black plastic ring that can be twisted. Undo it like a jar until it stops and with a bit of "jiggling" the bulb should come right out.
Then again your car is 10yrs newer so it could be different, but you'll know right away.
SR5_4WD is offline   Reply With Quote
