new rims - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2005, 11:42 PM   #1 (permalink)
View taz d's Photo Gallery
AE92 new rims
hey everyone. im new here so this is my first post.
i have been looking around and i saw a lot of posts about rims and i have my own questions.
i have an AE92...91 rolla, and i found a sweet deal on rims. They are 17 inch rims. what would be the best tire size for this? thanks for your help.
taz d is offline   Reply With Quote
Old 08-19-2005, 02:03 PM   #2 (permalink)
View 92MX83's Photo Gallery
If you're going to run 17" rims, be advised that:
1) Your car will accelerate even more slowly, due to increased rotational inertia
2) Your car will ride about 1/2" higher than normal, since the effective rolling diameter of the tire will be an inch greater than the correct diameter. Allow me to elaborate...
The narrowest tire offered in a 17" size is typically the 205/40-17. This is the correct +3 upgrade for a car running a stock 185/65-14 tire (say, for instance, an AE101). Previous Corollas like yours ran a 185/60-14 (GT-S model), or a 175/70-13 (base/SR5/DX/LE models). Since the profile of the tire is 5% lower, you'd need to find a 205/35-17 tire to have the correct rolling diameter... which no one makes, and likely never will, since very few cars come with a 23" diameter tire nowadays. But hey, aside from the slower acceleration, and possible clearance problems by going with a 17" rim, you may experience a marginal increase in fuel economy due to the higher overall gearing which the oversize tire gives the car. Then again, there may be a net decrease in fuel economy since the tire will have higher rolling resistance and inertia, and slightly worse aerodynamics.
The correct upgrade for your car would be a 205/40-16, of which there are a few brands who make this size. The 16" wheel would also be lighter by a few pounds (don't underestimate the benefit of this, as weight hurts most the farther out from the hub it goes), or more than a few pounds if you get the right (read: forged) wheel. Your offset is key here; if your offset is too low, you're going to have a wheel that sticks out and rubs the fenders, to high and they'll rub the strut assembly. I think around a +40 offset is okay (though I am open to correction on this).
Good luck to you!
"Crush enemies, see them driven before you, and hear the lamentation of the women!" - Conan the Barbarian, on what is good in life
92MX83 is offline   Reply With Quote
Old 08-19-2005, 05:56 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
16s should be the biggest to go on an AE92, 17s are overkill. Also 7inch width is the most you can go with depending on offset. I have 15x7 with 43 offset and they clear both fender and struts very nicely.
True that 205/40-16 and 195/50-15 are the plus size for the 185/60-14, but for ride quality you can also run 205/45-16 and 195/55-15s with minimal effects to your speedo.
Old 08-19-2005, 06:01 PM   #4 (permalink)
TokyoRacer's Avatar
View TokyoRacer's Photo Gallery
Yeah I have 15x6.5" wheels with a 40 offset and theres literally like 3-5mm between ym strut and tire..the little hairs on my tire rub the dirt off that part of my strut.
Kyle's 1990 Corolla SR5 - 2001 Protege ES
TokyoRacer is offline   Reply With Quote
