mine did that too.... you have to take that panel off that has the switch... with the car so that you can get power to the switch on, you'll see a screw that should be turning... i believe it's gold..... you either have to tighten or loosen... it's there so that when it closes the motor doesn't keep going... but if you loosen it just enough it works perfectly w/o ANY problems (mine's been like this for almost 3 years and NO problems) and the motor will run just a little bit if you hold it down and it's already shut, but it works flawlessly.....
you'll see what i'm talking about when you open it.... if you don't i'll go down and remove mine and take a pic and point it out for you.....
