Need Body Panel (Question) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2005, 09:55 AM   #1 (permalink)
Fast Toy enthusiast 4ever
drift_ae86_91's Avatar
View drift_ae86_91's Photo Gallery
AE86 Need Body Panel (Question)
Ok guys I know this is probably the wrong section but I have a question...
What piece would I need to replace this is it the quarter panel? Mine is on the right, this is VinnyQH's coupe but mine is just the corner of the tail light not the other part.
THANKS IN ADVANCE!!!
T-VIS= toyota.variable.impatience.system=D
1985 Corolla GT-S Coupe
2002 Subaru Impreza 2.5TS
1991 Toyota Tercel 2Dr "S"
drift_ae86_91 is offline   Reply With Quote
Old 08-26-2005, 04:36 PM   #2 (permalink)
.....drifto time.....
View etxxz's Photo Gallery
the 86's 1/4 panel is part of the roof and other 1.4 panel...all welded to the sheet metal. So, get yourself a dremel to cut the rust out or start sanding down the rust. (spray some rustoleum)
Then Buy some body filler, more sand paper *80 grit and 400grit* and fix it...its very cost inneficient to replace the body panel...looking at $700minimun. vs $40min
"Charles Xavier, from X-MAN tried reading Jack Bauer's mind once and now he's on a wheelchair"
99 A 3.2TL Nav | 88 332is [rip] | 88 332is ; ]
86 Ae86 20v, trd susp&lsd [sold]
etxxz is offline   Reply With Quote
Old 08-26-2005, 07:15 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Noooooo... not filler. Cut the rust out or sandblast it to see if its rusted through. If its rusted through, then cut the metal and weld new metal in there. Then slight bondo and epoxy primer, regular primer, top and clear coats. Should last after that.
Old 08-26-2005, 07:26 PM   #4 (permalink)
its surface rust...yeah they are all together roof etc
