How do i install this? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2005, 07:10 PM   #1 (permalink)
View GuJu MaN 89's Photo Gallery
I want to add this muffler to my 97 Toyota Corolla:
http://www.cardomain.com/item/APC159010
how would i install it?
what tools what i need?
GuJu MaN 89 is offline   Reply With Quote
Old 08-26-2005, 08:26 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
A trip to your local muffler shop should solve that.. and probably $50 to get it installed.
if not.. buy your own welder, cutter, pipe bender, muffler piping, etc..
Old 08-27-2005, 10:22 AM   #3 (permalink)
View tashirosgt's Photo Gallery
Guju Man,
The only new muffler that you can put on with simple hand tools is a stock Toyota muffler. See if your car has one. It includes a section of pipe upstreamd of the muffler as well as the tail pipe down stream of it. There are some thick rubber straps that stretch betwen hangers on the fame of the car to hangers mounted on the exhaust parts. A genuine Toyota muffler comes with the hangers mounted on it and has the pipes already welded to the muffler and bent in the right shape. If you already have an aftermarket muffler on the car then you will see that the muffler shop has improvised some way of hanging the muffler on the frame. (I think they do a better job by welding the hangers on the aftermarked exhaust parts than by using metal strapping.) The shop also must weld the section of pipe just upstream of the muffler onto the muffler. You do see fittings in auto parts stores that let you join exhaust pieces together without welding, but I don't think this is a good way to rig an exhaust. If you can do welding then you can probably improvise some way to do any cutting and bending of the pipes. If you are not a welder then the only do-it-yourself muffler job you want to tackle is replacing a genuine Toyota muffler with another genuine Toyota muffler.
tashirosgt is offline   Reply With Quote
Old 08-27-2005, 11:19 AM   #4 (permalink)
Fast Toy enthusiast 4ever
drift_ae86_91's Avatar
View drift_ae86_91's Photo Gallery
welder, cutter, pipe bender, muffler piping $1200 (??More??) wasting all that fucking money when it would cost ya $50-priceless
this has been a commercial for mastercard/owned corp.
if you lived in gta area, I would have said, don't go to spitfire performance (saw the work the did on a mr2 turbo ...
yeah it shouldn't cost any thing..
T-VIS= toyota.variable.impatience.system=D
1985 Corolla GT-S Coupe
2002 Subaru Impreza 2.5TS
1991 Toyota Tercel 2Dr "S"
drift_ae86_91 is offline   Reply With Quote
Old 08-30-2005, 12:43 AM   #5 (permalink)
View allenk's Photo Gallery
2003 Toyota Corolla
I want to replace the muffler with a bigger one. Does it have any affect when I get a smog check in the long run?
allenk is offline   Reply With Quote
Old 08-30-2005, 01:32 AM   #6 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
For smog? most likely not.
Now getting a bigger cat - That'll probably do something to your smog numbers
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 08-30-2005, 03:17 AM   #7 (permalink)
KDM is in
REN69's Avatar
Yeah.. as long as you're not taking out the catalytic converter, you should be ok. once you mess with that then you'll be lucky to pass smog/emission tests.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
