Originally Posted by REN69
Because the Camry already came with a S motor.  (3SGE or 3SFE, Can't remember off hand) The Corolla came with an A motor (4AFE) so the motor mounts are in different locations.
Its not like I cant weld new, stronger mounts in the stock local. I just found out that the MR2 Turbo axels will fit into the Corolla All-Trac hubs
So, with the celica alltrac transmission and MR2 turbo axels, along with some cutting and rewelding of the motor mounts we should have the front end figured out. The celica and corolla driveshafts will both have to be cut to make one hybrid drive. The rear diff drive ratio seems to be the only real problem right now since I dont really want to be messing around with changing out the rear axel. That would force me to do some custom suspension work that I would like to avoid.
Any input on how I can change out the rear ratios would be wonderfull. Are there any other toyotas that use a similar live axel. If there are I could borrow a gearset from one of those.
