metal scrapping noise from corolla xrs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2005, 10:42 PM   #1 (permalink)
corolla xrs
dawg's Avatar
View dawg's Photo Gallery
Hey Guys,
I hear a metal scrapping noise when in a gear and mostly when decelerating. I don't hear the noise at all when rolling in neutral with the clutch disengaged.
I have seen a couple of threads on this subject but none of them actually mention the cause of the problem or how it got fixed. I assume this is common in the xrs at about 10 thousand k's.
Is this related to the clutch or heat sheild?
dawg is offline   Reply With Quote
Old 08-29-2005, 01:32 AM   #2 (permalink)
9THGEN GURU
View jcturbo's Photo Gallery
actually it's common in any toyota vehicle equiped with the c60 6speed. even the guys in Australia experiance this problem. no real known cause yet.
jcturbo is offline   Reply With Quote
Old 08-29-2005, 08:29 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
if it doesnt cause damage or slow you down, fuck it.
Old 08-29-2005, 10:01 AM   #4 (permalink)
'10 XRS (05 & 09 XRS RIP)
rolla-XRS's Avatar
Gameroom cash: $100860
View rolla-XRS's Photo Gallery
I believe it's the clutch plate making the noise because the XRS clutch plate uses rubber/plastic nodes rather than the 4 metal springs. Interesting enough I've been told it's the Echo clutch plate. It's the four plastic nodes vibrating around that make this noise...similar to the heat shield. This is what happens when you get a stripped down Celica GTS. There's nothing wrong with it - it's just the way it was designed.
That said, whenever your clutch plate get's burned, replace it with the Celica version using metal springs and you'll be a-okay.
rolla-XRS is offline   Reply With Quote
Old 08-29-2005, 10:05 AM   #5 (permalink)
Fast Toy enthusiast 4ever
drift_ae86_91's Avatar
View drift_ae86_91's Photo Gallery
It's a way of life isn't it, thats weird, even in austrailia, cool, not cool but interesting
T-VIS= toyota.variable.impatience.system=D
1985 Corolla GT-S Coupe
2002 Subaru Impreza 2.5TS
1991 Toyota Tercel 2Dr "S"
drift_ae86_91 is offline   Reply With Quote
Old 08-29-2005, 10:57 AM   #6 (permalink)
9THGEN GURU
no it's not an echo clutch. it's the same part number for celica and matrix
Old 08-29-2005, 12:21 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Naah, its just that it seems like people worry too much about sounds, vibration, etc on their cars, even when their cars are relatively new. You have to remember, cars are mechanical things and they wont ever be "quiet". When you've driven cars that are literally almost gonna fall apart on you when you drive you get numbed to things like small noises. Best sounds I've known are when you go 120kph the whole car starts to rattle and body panels start to creak, and you keep on pushing it to 180ish, damn imagine how it feels then...
IMHO the worst mechanical problems are the ones that come silently, like fuelpump failure, never heard it coming, until hte whole dashboard lit up like a christmas tree.
Old 08-29-2005, 07:14 PM   #8 (permalink)
rolla-XRS's Avatar
Sorry - should have been more specific. The same stupid plastic springs are on the Echo clutch. Sort of a hybrid...Echo springs + Celica clutch plate = Corolla noise.
The Corolla XRS and Celica GTS clutch plates are different - and they have different part numbers....but the Ceilca clutch is better. Get that when the time is ripe.
Old 08-30-2005, 04:37 AM   #9 (permalink)
9THGEN GURU
31250-12360-84 is the number both the celica and the Corolla, spend some time on New Celica.org and you'll see them complain. the only way to get the sprung clutch is to order the Toyota OE clutch from Japan, or switch to TRD
Old 09-15-2005, 04:34 PM   #10 (permalink)
Toyota Fanatic
View ice_d_mugg's Photo Gallery
This noise would sound to me like it is your input shaft bearing, does it do it with the a/c on? i have a c60 with 10,000 miles on it and its doing that too, it doesnt seem to hurt it, but toyota will give you a new tranny as long as your still under warranty.
ice_d_mugg is offline   Reply With Quote
Old 09-15-2005, 05:20 PM   #11 (permalink)
rolla-XRS's Avatar
Humm...I seem to remember a tech telling me that a prior year Celica GTS clutch plate was the one to get. Might have been the 2003 or 2004 clutch. I can't remember right now.
