94 Corrolla Steering Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2005, 06:08 AM   #1 (permalink)
View rizy102's Photo Gallery
hiya,
got a 94 corolla executive and ive had the tracking done and tyres changed but still the car pulls by itself to the left. if i let go, the steering wheel is straight but the car pulls to the left. i have to keep the steering whell slightly pulled to the right.
what could it be?
thanks
rizy102 is offline   Reply With Quote
Old 08-30-2005, 06:48 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Pardon the ignorance.. but what's tracking??
As for the wheel pull.. sounds like you need a wheel alignment.
Old 08-30-2005, 07:56 AM   #3 (permalink)
View tashirosgt's Photo Gallery
Are you sure that the steering wheel is on straight? If you've had work done on things like radios or dash lights, the steering wheel should be removed in the process of taking the dash apart. It isn't unusual for one's first guess about how to put the wheel back to be wrong. (If you search for "steering wheel upsidedown" on the web you will find many instances of this complaint against auto shops.)
tashirosgt is offline   Reply With Quote
Old 08-30-2005, 08:58 PM   #4 (permalink)
tracking is wheel alignment. also the steering wheel has not been removed. if you let go of the wheel on a straight road it goes to the left therefore the steering wheel being put on wrong has nothing to do with it.
thanks
Old 08-30-2005, 09:18 PM   #5 (permalink)
Well, to grasp at straws, in the US we have the terminology "2 wheel alignment" and "4 wheel alignment" If you had all 4 wheels aligned by a good shop, they would probably have detected any suspension problems like a frozen ball joint , worn tie rod, bad CV joint. That would leave things like a misshapen tire or a brake dragging on one side. What does your tread wear look like? Is it even on all tires? When you stop, is the pull to one side noticeable?
I don't know what the symptoms of a bad differential would be. Has anyone had one of those problems?
Old 08-30-2005, 09:20 PM   #6 (permalink)
View Damemorder's Photo Gallery
Check your tyre pressure, suspect low pressure on the side it pulls to.
If that's not it, lift one side, Put your hands at the 9 o'clock and 3 o'clock positions and try to move the tyre. If the tyre moves without the steering wheel You need tie rod work, Although the shop you had the tracking done at should have told you if this was a problem.
'90 Geo Prizm AE92, 4A-FE, Auto 189K miles | Spray painted headliner | DuraStop pads/shoes | Dual Cathode trunk light | Durabrand CD | Shaved badges and molding
'93 Light Beige Metallic Bonneville SE 187K miles | Disassembled for rebirth
Damemorder is offline   Reply With Quote
Old 09-01-2005, 04:50 PM   #7 (permalink)
tyre tread even, and doesnt pull to one side when braking. ill check what Damemorder sed and let you know.
thanks
