"totaled" AE-92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2005, 10:51 AM   #1 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
"totaled" AE-92
What's up guys? I just had a quick question and need some opinions. My old '89 4A-F 'Rolla got hit in the front left corner which pushed it towards a curb. The other guy was at fault so insurance took it from there. The damage was estimated at 1400 bucks because of a bent lower control arm, plastic apron, and bent engine mount. My question is: How feaible is it to fix this car myself? They offer a 1g and they keep the car or 840 if I want cash and car. I choose the car 'cuz I can't part with that thing. So, what's the total cost of the mount and control arm and is anything hard to fix? I'm mechanically inclined but I will be making this a wrench monkey weekend with some buddies so it's going to be fixed one way or another. Is there other damage that can be present? CV Joint?
Thanks for your help
Gotta go get the 'rolla now... so.. laterz.
P.S. How hard is an engine swap to a 4AGE block? Any other things that need to be changed since this thing is a carb going to EFI?
Lord_Anarchy is offline   Reply With Quote
Old 09-02-2005, 11:48 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Depends on how its bent, you might need to use an autorobot on it.
Old 09-02-2005, 12:17 PM   #3 (permalink)
5SFE
I just ran by the shop to see it myself. The lower control arm on the passenger front tire is bent upwards (the accident had the tire hit the curb) but the CV, Tie, and shock mount are all fine so it's really just the lower control arm. The apron was damaged on the front left side but nothin' severe. I'm assuming the rim is bent so that'll be purchased. All n all, I guess I'll be needing a new control arm. What's the retail for one of those?
Old 09-02-2005, 12:36 PM   #4 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
screw retail, hit a junk yard and get one. if thats really all the damage, thats what id do and pocket the change.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 09-02-2005, 12:40 PM   #5 (permalink)
View karugs's Photo Gallery
Make sure the frame is not bent. An engine mount bending is a red flag.
karugs is offline   Reply With Quote
Old 09-02-2005, 07:28 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
yeah... I wouldn't keep it if I was you.. maybe to sell for parts but not to drive it.
Old 09-02-2005, 08:37 PM   #7 (permalink)
View Damemorder's Photo Gallery
I'd keep it... Get a factory manual, Most of them have measurements for the body. Within 10mm is good enough.
I actually bought my Bonneville wrecked too, I put a hood, headlight, fender, and about 20 hours into fixing it. I'm 1mm too low, 2mm too far in and 1mm too far back from what the car left the factory at. I say it's close enough. I only used a chain, a cheap arc welder, and a magnolia tree. You can fix it.
'90 Geo Prizm AE92, 4A-FE, Auto 189K miles | Spray painted headliner | DuraStop pads/shoes | Dual Cathode trunk light | Durabrand CD | Shaved badges and molding
'93 Light Beige Metallic Bonneville SE 187K miles | Disassembled for rebirth
Damemorder is offline   Reply With Quote
Old 09-03-2005, 02:57 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
I was taught that tolerance is 3mm in autobody repairs, not 10mm, 10mm is still a banana.
Old 09-03-2005, 07:37 AM   #9 (permalink)
KDM is in
REN69's Avatar
You're better off swapping the whole motor, you'll need motor and harness, ecu, transmission (C52 as opposed to C50 on your SR5) probably an upgrade of your fuel system (fuel pump, fuel lines), and upgrade to GTS front suspension
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 09-05-2005, 04:33 AM   #10 (permalink)
ZXT
View ZXT's Photo Gallery
Yeah If I were you I'll put in a whole engine, maybe a 4AGZE.
ZXT is offline   Reply With Quote
Old 09-05-2005, 03:01 PM   #11 (permalink)
dirt666's Avatar
View dirt666's Photo Gallery
Guarranteed if your control arm is toast, then the frame is fucked also. If you fix it, do me favor and keep it off the roads I drive on ....this is why we need to have safety checks. To prevent some no mind from driving his shitbox down the road veering into oncoming traffic after it's been glued back together..........
dirt666 is offline   Reply With Quote
Old 09-05-2005, 10:27 PM   #12 (permalink)
View nofuturefilmer's Photo Gallery
ok changeing the control arm is no problem its a matter of taking off the wheel strut tower tie rod strut bar raidial bar i believe its called and the control arm bolt
nofuturefilmer is offline   Reply With Quote
