93 toyota corolla rear speaker voltage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2005, 01:18 AM   #1 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
Hi,
Right side rear speaker in my 1993 toyota corolla is not functioning. Can any one tell me what should be the voltage across this speaker. I want to check if there is any problem with the wiring.
If any one of you guys had this problem in the past.. please tell me the solution.
thanks.
celica2004.
celica2004 is offline   Reply With Quote
Old 09-04-2005, 01:37 AM   #2 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Because of the nature of the signal, it's going to be a varying voltage. Your best bet would be to try another speaker, or hooking the speaker up to another source.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 09-04-2005, 03:15 AM   #3 (permalink)
View crim's Photo Gallery
well i did have problems in my 91 but i didnt care enough to check the wireing. i put some new ones in and they worked great. i tore out my back seat and everithing that was close to the back seat so they dont work so well anymore actually they dont work at all.
crim is offline   Reply With Quote
Old 09-04-2005, 02:20 PM   #4 (permalink)
4AC 4 Life
View Cavi Mike's Photo Gallery
Voltage across a speaker? What? It's not a headlight man. There is no specific voltage across a speaker.
#1. It's AC
#2. It depends on how loud you turn up the volume
#3. It will go much higher if amplified
#4. You shouldn't be using a multitester if you didn't know these basics
pearls ain't free
Cavi Mike is offline   Reply With Quote
Old 09-04-2005, 04:01 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
If either speaker is not sounding, then chances are you have a wiring problem. If you wanna bother with finding out where the wire is cut off.. go ahead, or you could just run a new wire and be done with it in less than half the time. If you still don't get signal, then chances are the deck is probably malfunctioning.. might as well just upgrade to a newer deck.
