Buy some decent tires and your problems will be noticably better. Go to a tire shop that sells tires and nothing else. Not brakes, not struts, not exhaust, but tires. Most people do not seem to understand the fact that tires are what meets the road, and is the biggest factor in how the car drives on the highway. These cars are so light that most front end components last much longer than the rest of the car. The struts on these cars are an issue, just don't think replacing them will cure all. More consistant with worn struts are these symptoms; bouncy, tends to wonder and float, etc. When I got my SR5 this June it had brand new top of the line Canadian Tire Sport All-Seasons(junk). The struts on my car are not very good either, but I didn't replace them. I went out and got some decent tires, I paid $47 Cdn ea for a set of Yokohama All Season TC320's from National Tire Wholesale in Delta. My buddy could not believe the diference it made in the handling of the car. If you have flat spots on your tires you will never get rid of your problems. With the tire balancing machines out there now, you can literally balance a square block....but how smooth does it turn? A decent tire shop will tell you this.
