Originally Posted by celica2004
It will of great help for newbies(repairing) like me if someone can post pics for oilchange and oilfilter change for 1993 toyota corolla. I couldnt find it online.
Pictures really arent necessary. I don't even know what the underside of a '93 looks like, and I can give you these detailed instructions:
1) Go to the store and buy a new oil filter and 4 quarts of oil.
2) Put car on ramps (Set ramps in front of the front wheels. Drive onto them, stoping before the end).
3) Go under the car.
4) Look at the bottom of the engine and identify the "oil pan". Hint: It covers the entire bottom of the engine.
5) On this previously mentioned "oil pan", look for a "drain plug", which looks like a bolt head and washer.
6) Below the "drain plug", place a drain pan, or bucket, to catch the oil.
7) Using a wrench, remove the "drain plug". Watch in awe as oil spills from the resulting hole. THIS IS NORMAL. When the flow of oil slows to a slow drip, continue to step #8.
8) Replace the "drain plug", and tighten with the wrench.
9) Get out from under the car, remove the oil filter you bought in step #1 from it's box, and look at it.
10) Go back under the car. Find the old oil filter. Hint: It looks just like the new one, only dirtier, and perhaps a different color. Nothing else down there looks like an oil filter.
11) Move your drain pan/bucket directly below the oil filter.
12) Using an oil filter wrench if necessary, remove the old oil filter. Then, drain the oil from the old filter into the bucket/pan.
13) Discard old filter.
14) Open up a quart of oil, and spread some onto the gasket surface of the new oil filter.
15) Screw the new filter on to the engine, where the old filter was. Hand tighten 3/4 to 1 full turn beyond the point where the gasket touches the engine.
16) Get out from under the car. Open up the hood. Find the oil fill cap. This is usually on the valve cover. Hint: The valve cover is the thing that covers the entire top of the engine, and the oil cap usually says "oil" on it.
17) After reading your owners manual to find the engine oil capacity, fill the engine with that much oil, through the open hole created by removing the cap mentioned in step #16.
18) Replace cap. Close hood.
19) Start car and carefully back car off of the ramps.
See? Nuthin to it.
