Shifting arm is too tall! 05 S - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2005, 04:55 PM   #1 (permalink)
View Indigo_I_Rolla's Photo Gallery
I have an 05 Corolla S and I hate how high the shift knob sits. I was wondering if anyone here knew if the short shifter lowered the height of the knob, and if it was the only option for lowering it. Thanks.
Indigo_I_Rolla is offline   Reply With Quote
Old 09-08-2005, 06:19 PM   #2 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
I cut mine down 1 1/2-2" and put a new knob on there.
Yes a short shifter should lower it
adsaba1969 is offline   Reply With Quote
Old 09-08-2005, 07:00 PM   #3 (permalink)
I was thinking about just cutting it. If you cut yours, how did you get the knob to stay on though?
Old 09-09-2005, 05:44 AM   #4 (permalink)
Whine connoisseur
the knob i bought is 2 pieces; a small bottom piece with female threads that is held in place by an o-ring and allen screws, the top just screws into the bottom. It doesn't move at all.
Old 09-09-2005, 06:35 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
A "short shifter" doesn't imply that your shifter lever is "shorter" it implies that the shifting points will be shorter, the arm is usually just as long as the regular one is but with a different shape and it may feel that the lever is shorter when its not.
Old 09-09-2005, 06:45 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
shortening the shifter length would also make the throw length shorter.
Old 09-09-2005, 04:42 PM   #7 (permalink)
Ren, thanks for your help. I know what the implications behind a short shifter are though, but I didn't know if anything out there for Corollas made the height of the arm any shorter, so that's what I needed to know. Adsaba, where did you get your knob? I think that's the option that I want to go with.
Old 09-09-2005, 07:17 PM   #8 (permalink)
Whine connoisseur
i got it at a local performance shop. I'm sure they have knobs with that setup anywhere that sells the kind of stuff
Old 09-09-2005, 07:56 PM   #9 (permalink)
KDM is in
REN69's Avatar
The knob I got on my 89 GTS actually goes lower than the OEM knob and it makes it feel like its lower. I'd say look for a knob that goes in deeper than the OEM and it might make a difference.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 09-09-2005, 09:25 PM   #10 (permalink)
View thoughthard's Photo Gallery
Try this...?
Remove shift knob. Cut shaft down to desired height. Take cut piece to Home Depot, Lowes, Ace Hardware, etc to find a die of the correct thread. Use the die to thread the shaft. Maybe use a file to clean up the rough areas from the cut. Reinstall shift knob.
thoughthard is offline   Reply With Quote
Old 09-10-2005, 11:55 AM   #11 (permalink)
Fast Toy enthusiast 4ever
drift_ae86_91's Avatar
View drift_ae86_91's Photo Gallery
ditto
T-VIS= toyota.variable.impatience.system=D
1985 Corolla GT-S Coupe
2002 Subaru Impreza 2.5TS
1991 Toyota Tercel 2Dr "S"
drift_ae86_91 is offline   Reply With Quote
Old 09-10-2005, 06:01 PM   #12 (permalink)
Anyone have any idea if any shop online sells anything like adsaba is talkin about? I would need specific names in order to do a search so if I could get those that would be great.
Old 09-10-2005, 06:13 PM   #13 (permalink)
Whine connoisseur
I just searched google for "manual shift knob" and got a ton of places. In the description of the knob it will tell you whether it screws on or not
Old 09-10-2005, 07:40 PM   #14 (permalink)
KDM is in
REN69's Avatar
Most aftermarket ones come with these plastic things with sizes on them that you can swap to screw onto different cars. My Civic was a size 10 and the Corolla as any other Toyota is a size 12 (I know this because my 90 GTS has an IS300 knob and it fits right in) I'm not sure what the number would imply, or if's the same number for all aftermarket knobs, but this is for my Ractive knob.
Old 09-10-2005, 07:58 PM   #15 (permalink)
Yea I have a Ractive knob right now, and finding knobs isn't any trouble at all. It's finding an arm that is lower than the stock one that is the trouble. I found one for 150 bucks which seems to be my best bet however it only lowers the hieght by 2.5''. It's not bad, but I'd like to find something a little lower. Thanks for all the help guys.
