I have a engine light problem, need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2005, 11:30 AM   #1 (permalink)
View rafa1383's Photo Gallery
hi, i have a 99 corolla and a few days ago the engine ligth turn on and i went to check it and it give me a P0125 code. I want to know what can i do to solve this problem cause the car is give me less millege per galon, but the car is running normaly with the temp. were i´ts shoulg be. Plizzzz give me and answer as soon as posible.
thanksss!!!!!
rafa1383 is offline   Reply With Quote
Old 02-01-2009, 02:54 AM   #2 (permalink)
View PortCityRolla's Photo Gallery
I went to the dealer and they told me that I needed a new water pump for p0125
PortCityRolla is offline   Reply With Quote
Old 02-01-2009, 09:19 AM   #3 (permalink)
just a nobody
The OP was from a few years back, so he probably have correct his problem. P0125 doesn't really have anything to do with the waterpump, needs a bank 1 sensor 1 Oxygen sensor maybe.
N.E.O.
Old 02-01-2009, 12:50 PM   #4 (permalink)
View toyomoho's Photo Gallery
As NEO posts, this code is often misleading.
Old 02-02-2009, 02:51 AM   #5 (permalink)
So are you guys saying that I should disregard the dealer's recommendation of replacing the drive belt and the water pump to clear the check engine light?
Old 02-02-2009, 07:11 AM   #6 (permalink)
just a nobody
OK! Just for reference, this is for a Camry, on page 61: http://www.camrystuff.com/manuals/Gen4/Diagnostics.pdf. Do you see any mention of the water pump for possible cause? Corolla is pretty much the same for the causes.
N.E.O.
Old 02-02-2009, 01:28 PM   #7 (permalink)
Do you know where i can find the part number for the O2 sensore for a 99 corolla?
Old 02-02-2009, 11:24 PM   #8 (permalink)
just a nobody
Check the sites vendor section for possible source of parts. A lot of members also use RockAuto.com for parts source too. Stick with Denso though if you go aftermarket.
N.E.O.
