tightening a throttle cable? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2005, 11:41 PM   #1 (permalink)
View Dicipleofthelie's Photo Gallery
is it possible to tighten a throttle cable?
it looks as if its at the end of the adjustment deal i dunno, but its oddly loose
current car: effed up AE-82 corolla
update: she spun a rod bearing... woooo
Dicipleofthelie is offline   Reply With Quote
Old 09-12-2005, 12:07 AM   #2 (permalink)
1 4/\/\ +3|-| |\|00|3
View dlichterman's Photo Gallery
would be nice to know what car your talking about
if its the "effed up" one you might want to look here
http://www.rollaclub.com/board/index...r%20cable&st=0
dlichterman is offline   Reply With Quote
Old 09-12-2005, 12:08 AM   #3 (permalink)
86 corolla sedan 4alc w/ carb
yeah sorry about that
Old 09-13-2005, 12:48 AM   #4 (permalink)
Dexterous's Avatar
View Dexterous's Photo Gallery
Had the same problem with my ‘99; the cable is stretched.
I loosened the cable nut slightly on the throttle body and started the car.
I adjusted the tube and nut gently, make sure you don’t cause your idle to go up.
Also, if you have cruise control you may need to adjust the cables behind the cover also.
'99 Corolla CE
'02 Sienna CE
Dexterous is offline   Reply With Quote
Old 09-13-2005, 02:05 AM   #5 (permalink)
no cruise control, and i think the adjustment nut thing is at max....but ill check that out
Old 09-13-2005, 01:19 PM   #6 (permalink)
View polo708's Photo Gallery
not sure of your model, but most should be adjustable where the cable meets the TB. There should be a part that is threaded, just tighten it from there.
2004 Supercharged Corolla S
polo708 is offline   Reply With Quote
