help- cooling fan. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2005, 11:04 PM   #1 (permalink)
View playa69's Photo Gallery
help- cooling fan.
since geo prizms have the same engine as the toyota corolla, i decided to come here for some help.
the cooling fan on a 1995 geo prizm we have is constantly running, even if the engine is cool. we've changed the temp sensor and the cooling fan switch. it still runs, what's the prob? can anyone help?
playa69 is offline   Reply With Quote
Old 09-13-2005, 11:24 PM   #2 (permalink)
no help??
Old 09-14-2005, 06:53 AM   #3 (permalink)
View jon the greek's Photo Gallery
try a geo forum
jon the greek is offline   Reply With Quote
Old 09-14-2005, 06:54 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
The prizm doesn't just have the same motor as the Corolla.. they're the same car with different looks to make them different.
btw, don't expect a reply in 20mins. It will take at least a few hours before someone who has experienced the same thing replies. I've had that happen to me but it was the temp sensor. Change the thermostat too.. maybe the car really is overheating and its not just the fan or switches acting up.
Old 09-14-2005, 01:18 PM   #5 (permalink)
i've waited a couple days now. i have tried a geo forum, they're not much help. from what i've researched, the 95 prizm and the 95 corolla do have the same engine, all the engine parts in our prizm have TOYOTA stamped on them.......so i decided i could try asking you guys for help......sorry if it's an inconvenience. i'll try the thermostat. i don't think the car is really over heating because when i start it up in the morning, it just runs, for no reason. thanx for the help.
Old 09-14-2005, 03:54 PM   #6 (permalink)
KDM is in
REN69's Avatar
Nobody said it was an inconvenience.. and as for the 20min thing.. I thought you posted the same day within 20mins didn't realize till after that you had posted the day after almost at the same time. I had 2 teeth taken out today so the pain was getting to me.
Try the thermostat.. it's probably stuck and the fan is just trying to keep the engine cool.. could be the rad too, push the fins on the rad, if they go right in without any effort then its time for a new rad.
Like I said, the Corolla and the Prizm are the same car.. the Prizm is basically a rebadged Corolla with different bits here and there, but they're both made at the same plant.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 09-14-2005, 09:46 PM   #7 (permalink)
fins on radiator...huh? so does the radiator effect the cooling fan?
Old 09-15-2005, 04:00 AM   #8 (permalink)
View karazy's Photo Gallery
It could be a stuck relay.
karazy is offline   Reply With Quote
Old 09-15-2005, 07:44 AM   #9 (permalink)
KDM is in
REN69's Avatar
Yeah.. the fins (little metal leafs on the rad) if you push them and the basically come right off, the rad is dead and of course the fan stays on all the time, because the rad doesn't cool the motor properly anymore.
Old 09-15-2005, 12:15 PM   #10 (permalink)
but what if the motor is cool......like when i start it up in the morning, the engine is cold, the radiator doesn't work when it's cold, but the fan just runs.
the relay is fine, i changed it.
Old 09-15-2005, 03:11 PM   #11 (permalink)
KDM is in
REN69's Avatar
Take it to a shop.. they'll probably figure it out if you don't. My best bet now is maybe you have bad wiring somewhere.
Old 09-16-2005, 12:21 PM   #12 (permalink)
that's what i was thinking
here's a quote from another forum.
No, but the ECT will pick up the temperature of it, and if that reads high the fan will come on. If the ECT wire is shorted with another wire or power, the fan will turn on.
There will be 2 wires I believe from the ECT sensor which should be located on or near the thermostat which should be at the end of the top radiator hose which connects to the radiator on top. One will be 5volts at all times and the other one should be less, like at least half that.
maybe that's it. any ideas.
Old 09-16-2005, 10:21 PM   #13 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Hm... looks like everything here is covered already.
If the fan relay is fine and the radiator is fine, and you've changed the temp sensor, just check the voltage on those ECT wires, and if that is fine, just take it to a shop.
Good luck!
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 09-17-2005, 01:04 AM   #14 (permalink)
what should the voltage read?
Old 09-28-2005, 01:46 PM   #15 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Step one: Cut 2 wires to fan
Step two: Ground one
Step three: Run wires to a switch inside
Step four: Connect one wire to battery and one to fan
Tada! No more expensive repairs. Just turn it on when the gauge (do Geo's have temp gauges?) reads 1/2 way!
Oh, and BTW, when Ren said this:
Note the word in BOLD. He didn't say it didn't have the same motor, he said the cars are almost the same!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
