how to loop PS pump lines? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2005, 11:30 AM   #1 (permalink)
View rollawreck's Photo Gallery
AE92 how to loop PS pump lines?
anybody know how to do this on a 90 SR5 (AE92)? i think im going to do this as my PS rack just took a crap.... adn i dont know how and searched out to the hills and cant find squat
rollawreck is offline   Reply With Quote
Old 09-14-2005, 12:23 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You'll still has stiff as shit steering.
Old 09-14-2005, 07:07 PM   #3 (permalink)
Danno
View 89yotarollagts's Photo Gallery
i just ripped everything out and called it done works fine for me takes awhile to get used to no power steering but i like it better
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 09-16-2005, 01:14 PM   #4 (permalink)
did u leave fluid in the rack when u did it? cause mine will not have any fluid in it and im worried it will fail and i wont have any steering at all and crash...
i cant find a power steering rack ANYWHERES here in Nova Scotia for under 200 bux at a junk yard and they want 350 for a remanufactured 1 and i dont have that kinda cahs right now...
Old 09-16-2005, 01:15 PM   #5 (permalink)
and does anybody know how to loop the PS lines? im thinkin of doing this. and Flashmn, i know how to drive a car without PS and i think i can handle it
Old 09-16-2005, 01:29 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Its impossible to have "no steering" even if it fails. its still mechanical.
Yes my corolla doesnt have ps either, BUT a PS rack is different than a manual rack, and its gonna be twice as stiff than a Non-ps rack. If you feel like I'm talking BS, well try it, its gonna suck.
Old 09-16-2005, 08:47 PM   #7 (permalink)
[QUOTE=Flashmn]Its impossible to have "no steering" even if it fails. its still mechanical.
no im not saying i dont belive u man, i drove it home from where it broke (not far) but i could tell it was pretty hard to fuckin turn at a stop. if i cant find a rack thats what ill hve to do tho
Old 09-17-2005, 06:46 PM   #8 (permalink)
Danno
i havnt had any problems with mine and ive been driving with it for about a year if not more without any problems... it is hard at first because you are so used to power steering but you get used to it eventually and will be easier the more you drive it... as for looping the lines i havnt heard nor seen this done..
Old 09-18-2005, 12:08 AM   #9 (permalink)
Gameroom cash: $134355
you need to cut the high pressure line where it connects to the pump, then the low pressure line will fit inside of the metal part that's left on the high pressure side.... then clamp it together (after adding fluid)...
i did this on mine when i did a motorswap...... it's stiff, but, oh well... i like it better the way it is
Old 09-18-2005, 03:30 AM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Thats because its a power steering rack. Just find a manual rack, and you're steering will be just fine, but non-powered.
Old 09-18-2005, 11:41 PM   #11 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Agreed, the manual racks are quite nice. A power steering rack running no fluid sucks But it is still usable.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 09-19-2005, 01:39 AM   #12 (permalink)
Gameroom cash: $156605
View redgtxdi's Photo Gallery
How and what is there to check on a PS setup. My '95 doesn't leak a drop of anything, but I was so surprised at 10 years old that I looked up under there when I was draining the coolant and noticed that everything along the steering rack looks a little moist.
Now I don't know jack about power steering, but I'm assuming that's power steering fluid seeping out from somewhered? Anything to do other than just adding PS fluid??
Any harm on just letting it weep a bit?? It's not enough to create a drop on the garage floor, just noticed it's the only thing that's not clean & dry in the engine bay.
TIA
redgtxdi is offline   Reply With Quote
Old 09-19-2005, 05:51 AM   #13 (permalink)
The Mad Scientist
Then I wouldn't worry about it. There's a power steering resevoir in the engine bay, just make sure it's filled up. Use ATF.
Old 09-19-2005, 02:05 PM   #14 (permalink)
OK, will do! Thanks Dr. Tweak.
It's the one piece I use to show people that it's not a Chevy....it's a Toyota!!
The PS reservoir cap appears to be stamped metal with a big "T" on it, then around the circumfrence of the "T", it says.........."TOYODA"
I wonder if that's George Lucas's *real* inspiration for "Yoda?" ........
Old 09-20-2005, 01:23 AM   #15 (permalink)
The Mad Scientist
What? Take a pic
