ae92 in trouble ineed help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2005, 08:29 PM   #1 (permalink)
View ae92corollaguy's Photo Gallery
Question ae92 in trouble ineed help please
i have '89 gts and i was taking my front bumber off and i took the hood off. I forgot to put it back on and it rained!!!!!!!! now ive got it running but it sounds like a lawn mower engine does anyone know what the problem could be?????? help please
ae92corollaguy is offline   Reply With Quote
Old 09-15-2005, 08:55 PM   #2 (permalink)
View tashirosgt's Photo Gallery
Rain should not do much to your engine. See if it s missing on one cylinder. Check for spark on all your plug wires.
tashirosgt is offline   Reply With Quote
Old 09-15-2005, 09:00 PM   #3 (permalink)
its all giving spark and ispent 30minutes drying out the spark plugs and wires and let it dry out for about 5 hours and its not accelerating like it was yesterday i had my foot all the way on the gas and itwas barely going any ideas
Old 09-15-2005, 09:17 PM   #4 (permalink)
how do i check that
Old 09-15-2005, 10:46 PM   #5 (permalink)
Was the car running well after the hood was off and before the rain? Or was it untested after the hood came off. Maybe it wasn't the rain that affected the engine. Maybe it was something you might have disconnected accidentally while working around the engine.
Old 09-15-2005, 11:35 PM   #6 (permalink)
View karugs's Photo Gallery
Check if air filter has water. Spark plug cylinders might also have water.
karugs is offline   Reply With Quote
Old 09-16-2005, 06:55 AM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Sounds like you got water inside the sparkplug valley
Take off the wires going to the plugs(make sure you remember which one is for which sparkplug) then remove the black cover on top of the the sparkplug valley (should be 6 bolts I think) then if you got a Shopvac vacuum, vacuum the water that's inside until its dry, now let it sit until the moisture dries off and put everything back on. and it should start.
I did something similar except I washed my motor and let it dry off, I figured no water would get in there.. then a couple of days later I tried starting the car and it wouldn't go. I figured the wires must be wet.. so I pulled the first wire out and look inside.. I had about 2inches of water in there. so I did what I explained to you before and the car runs now.
Old 09-16-2005, 03:37 PM   #8 (permalink)
the engine was running gr8 b4 i took the hood off and it only started running wierd after the rain and the first thing i did was take the valley off and th spark plug wires out dried the valley and let the wires dry the car is really driving wierd no and it has no acceleration and its eating gas like crazy and its rieking of gas fumes the intake is dry its really busting my brain to figure out whats wrong with it. the car sounds like a lawn mower when i give it gas
Old 09-16-2005, 05:11 PM   #9 (permalink)
OK, you tested for spark on each plug wire individually, not by testing only one plug ? Did you do this by taking out each plug, Hooking the plug back to the wire, setting the plug on a metal part of the car, cranking and seeing there was spark on the plug? As karugs suggested, you checked that the air filter is dry?
Like Ren69, I've often washed my 4af and 4afe engines, I use a garden hose. But that has not caused me any problem. Is this a 4age, fuel injected?
The engine sounds like a lawnmower. Lawnmower engines are loud. Has the exhaust manifold cracked?
If my 4afe was having this problem and each individual plug wire worked, I would idle the car and hold a pipe or piece of broomstick up to the body of each of the 4 injectors and listen to them. They make a click-click-click sound thst is easy to hear when they fire. I would disconnect the ends of various vaccum lines and see if I found water in them - not that I can explain how this would happen. While I had the spark plug wires out, I might see if I could detect water in the cylinders. As I got more perplexed I would change the oil and filter and look for water in the old oil. I might take off the valve cover gasket and look for water in the head. If you do this on the 4af or 4afe, notice the dabs of gasket compound that are placed around the ends of the cam shafts, you need to clean these off and replace it with new compound, or the head will get a minor oil leak at those places.
Old 09-16-2005, 07:36 PM   #10 (permalink)
KDM is in
REN69's Avatar
is different with 4AF/4AFEs as they don't have a valley. 4AGEs do and that's why the water gets in there when you wash them.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
