'90 Corolla sedan middle brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2005, 11:46 PM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Is it a common problem for the middle brake light for 88-92 Corolla to not work? My dad's has been out for a while. I tried changing the bulb, but it did nothing. There is no power to it with a multi-meter. I'm thinking maybe a bad ground? I can't see where the wires go into it from underneath...
The reason I ask whether or not it's common is because I've seen a few other Corollas around withe the same problem.
2007 Camry 2.4L 5M
Old 09-17-2005, 11:47 AM   #2 (permalink)
View tashirosgt's Photo Gallery
Fotunately, for purposes of this question, my rear dash (or shelf or whatever one calls it) in my 1990 is missing. The middle brake light wires go from the drivers side of the light across the rear dash in a recessed valley under the missing dash to the molding on the rear side of the drivers rear door. They go under this molding, the section on the bottom half of the door. I don't know what happens after that. The harness has several wires in it, I think 4 of them are for the speakers. There are 2 brake light wires. One is green, with pairs of red stripes (incomplete stripes, like someone put dashes on the wire with a Sharpie). The other one is white with pairs of stripes. (The white wire with single stripes and the red wire with single stripes goes to the passenger side speaker.)
tashirosgt is offline   Reply With Quote
Old 09-18-2005, 12:46 AM   #3 (permalink)
View Damemorder's Photo Gallery
The problem is inside the light. You'll see where there's a screws connecting the wire to the socket, Solder that. Bad ground. Same thing with the other brake lights not working.
'90 Geo Prizm AE92, 4A-FE, Auto 189K miles | Spray painted headliner | DuraStop pads/shoes | Dual Cathode trunk light | Durabrand CD | Shaved badges and molding
'93 Light Beige Metallic Bonneville SE 187K miles | Disassembled for rebirth
Damemorder is offline   Reply With Quote
