heavy duty brake cleaner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2005, 10:38 AM   #1 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
I read the instructions and they were bit confusing. Can any one tell me whether is it worth to use this product for cleaning my 93 corolla breaks.
WTF?
celica2004 is offline   Reply With Quote
Old 09-17-2005, 11:04 AM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
They are pretty much the same. You use it to clean brake system, get rid of gunk, dirt, and brake dust when you replace pads, shoes, calipper, drum, etc...
93 ST185
ST185 is offline   Reply With Quote
Old 09-17-2005, 11:05 AM   #3 (permalink)
View tashirosgt's Photo Gallery
I haven't read the directions on that brand, but brake parts cleaner is good for removing thin oily films (and removing adhesive labels from jars! ). It isn't very good for heavy duty cleaning.
The surface it is important to clean is only where the pads rub on the drum or disk. On old brakes it is generally very shiny and not in need of cleaning. This surface does not need "routine cleaning". When you work on your brakes you get that surface oily because your hands are oily. In that case you clean it with brake parts cleaner. I spray it on the surface and wipe the surface with a clean rag or paper towel. It isn't necessary to clean the other parts of the brakes. If want to clean the other parts of the brakes just to make them look nice it probably works just as well to use something like "Orange power" cleaner and water. Don't get the brake pads wet. Then you may need to apply grease to some of the moving parts. Use the brake parts cleaner last to clean the braking surfaces last since you will get some residue on them from your other cleaning and greasing.
tashirosgt is offline   Reply With Quote
Old 09-17-2005, 12:33 PM   #4 (permalink)
celica2004's Avatar
I am not working on my breaks now. But I am wondering if I just spray this break parts cleaner on my brake rotor (without removing tires), will it remove the dust and incerease the friction between rotor and the pads?
thanks.
WTF?
Old 09-17-2005, 01:04 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
No it wont. Pads create dust and they have most grip when the rotor and pads are dry.
