New 06 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2005, 07:42 AM   #1 (permalink)
View Stan_06Corolla's Photo Gallery
New 06 Corolla
Hello all. I just bought a new 06 Corolla, automatic and I thought I'd introduce myself here and ask a few questions. As I was perusing the owners manual, I noticed that you're supposed to periodically tighten the drive shaft bolt. I didn't notice a torque spec on this, and was wondering why it needs to be periodically tightened (I would have thought if it was prone to come loose, they would have put a lock washer or something on it), and what to torque it to? Also, since I'm planning on doing my own oil changes, I was curious as to how difficult it is to get to the oil filter? I'm hoping it's not hidden behind a bunch of other stuff that requires you to be double jointed before you can remove it. I also noticed that there was no interval specified for changing the timing belt. I'm not a mechanic, so I'm assuming that since it is a VVT engine, there is no timing belt....is this a good assumption?
So far (500 miles later), I'm pretty impressed with the little car. It gets significantly better milage than my pickup truck, which is the primary reason I got it. It's pretty peppy, though it's certainly not a sports car. Speaking of which, anyone know what the HP and torque specs are on it?
Thanks.
Stan_06Corolla is offline   Reply With Quote
Old 09-18-2005, 03:07 PM   #2 (permalink)
View jasontoy's Photo Gallery
drive shaft bolt
I asked the same question about the drive shaft bolt. Nobody seems to bother checking it, or even no about the scheduled maintenance.. I have 35k on my 05 with no problems......
jasontoy is offline   Reply With Quote
Old 09-18-2005, 03:15 PM   #3 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
Thanks.
check here http://www.edmunds.com/new/2006/toyo...067/specs.html
Base Engine Type: Inline 4
Horsepower: 126 hp
Max Horsepower: 6000 rpm
Torque: 122 ft-lbs.
Max Torque: 4200 rpm
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
