Swapping GT-S cluster into SR5... just plug and play? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2005, 12:25 PM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
I wanted the higher MPH speedo and the higher redline tach, so I bought a GT-S cluster (with 342,000 MILES on it!)
Do I just swap it in, or will the speedo be off?
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 09-18-2005, 12:32 PM   #2 (permalink)
Gameroom cash: $134355
it will be correct
Old 09-18-2005, 07:26 PM   #3 (permalink)
View snakoil's Photo Gallery
you'll need to rewire some plugs to have the door light in the new cluster to light up but other than that it just fits right.
snakoil is offline   Reply With Quote
Old 09-18-2005, 09:23 PM   #4 (permalink)
omg jdm
aaron7's Avatar
Can I not rewire it and just keep the door light on the dash? Or will the cluster do weird things?
Old 09-21-2005, 08:41 AM   #5 (permalink)
omg jdm
aaron7's Avatar
Works great! And the speedo isn't off!
Old 09-22-2005, 12:01 PM   #6 (permalink)
sorry bro haven't seen your reply...no you don't have to!
nice knowing it works well!
Old 01-02-2006, 04:08 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
yea the speedo, tach, fuel and temp gauge will all work. You don't have to rewire anything to leave the light where it is. I had it in for a bit but then thought why? my engine can't use the redline on that tach. And unlike my sr5 speedo it can't beat the gts speedo's top speed :P
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 01-02-2006, 04:22 PM   #8 (permalink)
omg jdm
aaron7's Avatar
yah, I put it in back in September...
Old 01-02-2006, 05:15 PM   #9 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
yeah I was trying to change the backlight color but I wasnt able to pull the cluster out enough to unplug it from behind. And in screwing with everything all I accomplished was frustration. I guess some things were never meant to be...
I also learned a lesson that day: If There's Nothing Wrong With It, Don't Screw With It !!!
SR5_4WD is offline   Reply With Quote
Old 01-02-2006, 06:50 PM   #10 (permalink)
Vroom?
freakinbox's Avatar
what are you talking about? it's so easy. there is enough slack and the plugs are so simple you shouldn;t need to see them.
Old 01-02-2006, 10:21 PM   #11 (permalink)
omg jdm
aaron7's Avatar
Probably the speedo cable was tight.
Old 01-02-2006, 10:37 PM   #12 (permalink)
Vroom?
freakinbox's Avatar
speedo cable is attached to the dash not to the gauges like you are thinkin. and the gauges just slide into it. after that it's just 2 plugs in the back which disconnect by pushing the tab then pulling. they don't come forward a whole lot I guess. I suggest lowring your stering wheel, makes it easier.
Old 01-02-2006, 10:41 PM   #13 (permalink)
omg jdm
aaron7's Avatar
Oh yah, that's right. I was very happy when I saw that since all my other cars had the speedo cable on the cluster and it was a pain to remove. So yah, probably just hitting the steering wheel or something.
